Pat's Easy Change - B7800
   / Pat's Easy Change - B7800 #1
MattBeef
SD
Pat\'s Easy Change - B7800
Does anyone have experience with this set-up?
From the product description, it seems that the "straight-line" on my lift arms are not long enough to make this work.
Any help / tips appreciated.
mlg
mlg
Re: Pat\'s Easy Change - B7800
None of you fellow B7800 owners have Pat's Easy Change? /forums/images/graemlins/shocked.gif
Interesting -- maybe this tells me I shouldn't buy a set, after all... /forums/images/graemlins/confused.gif
mlg
mlg
   / Pat's Easy Change - B7800 #5
I just installed them on my B7800 a couple of months ago and didn't have any problems. I can email or post some pictures if you think it will help.
   / Pat's Easy Change - B7800 #6
   / Pat's Easy Change - B7800 #7
I just installed them. They work fine. The optional separator arm is flimsy, but it does what it is suppose to. You still need to have something to keep the arms separated the right distance. Unless you make one of your own theirs is OK.
/forums/images/graemlins/smirk.gif
   / Pat's Easy Change - B7800 #8
   / Pat's Easy Change - B7800 #9
The objective is to keep the lower 3ph arms at the same distance apart and from swinging around wildly.... so, I use a bungee cord to hold them together and set the links for the right distance apart... works for me and the bungee cord flexes around when needed.
   / Pat's Easy Change - B7800 #10
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2024 John Deere 872GP Articulated Motor Grader With GPS Package (A52143)
2024 John Deere...
