gwdixon
Elite Member
One of the things I struggled over when ordering was whether to go with straight Cat 2 or the Cat 2 to Cat 1 since I currently do not have any Cat 2 implements. Did not realize there were Cat 1 and Cat 2 washers. If the lynch pin closes how will the size of the washer change how it functions?
I'm with SPYDERLK big time on this one. He stated, "your problem is mostly due to use of cat 2 washers on cat 1 pins. The grinding will just help a little. Get some 7/8" washers."
That CAT 2 washer, even ground down, will float and flop around on the CAT 1 lift pin. You could call Pat's and order the CAT 1 bent washers or just go to the hardware store (with the CAT 1 lift pin in hand) and buy washers that barely fit on the pin; 7/8" as SPYDERLK mentioned.
This washer issue was posted in #113 but since you didn't realize that there were different size washers it must not have made sense.
The last photo of the modified washer by grinding shows that it is not sitting perpendicular to the lift pin. That is a problem with using the wrong size washers. My original post (way back there, #104) shows different sized washers used for the "invention" for them to securely fit CAT 1 and CAT 2.
