Peak torque ratings and associated rpm?
   / Peak torque ratings and associated rpm? #13
Torque and HP are directly related.
Torque = (HP * 5,252) / RPM or HP = (Torque * RPM) / 5,252. The relationship is exact.
Don't get confused by the 5,252. It is a conversion factor only, and comes from the fact that a 1-foot circle has a diameter of 6.2832 feet. Dividing 33,000 by 6.2832 gives you 5,252, which simplifies the equation and resolves the units. This constant is the reason that horsepower torque graphs ALWAYS cross at 5,252 RPM.
Torque is in pound-feet. 1HP = 33,000 ft-lbs / min or 550 ft-lbs / sec.
So, 43 HP @ 1,700 RPM = 132.8 lb-ft of torque at 1,700 RPM. Now if only we could get all that torque to the ground without wheelspin!
   / Peak torque ratings and associated rpm? #14
Never posted a link before, but I found this http://vi.dzima.com/wp-content/uploads/2015/01/Daedong-Kioti-Data3.pdf
1700 rpms for the 3F183T engine family.
On Page 5 it says my CH2510's engine makes max torque of 5.9 at 1900 rpm, but rated hp of 24 at 2600 rpm. And the torque/power chart shows essentially the same torque from 1000 rpm to 1900. Interesting and confusing.
EDIT: Interesting also that I do BH operations at 1800 rpm; always have based on advice on this site. But everything is slower at lower rpm, I guess because the pump is running slower.
   / Peak torque ratings and associated rpm? #15
I'm not sure which engine is in your ck2510. Kioti's website says 3a165LFB and Tractor Data says 3a139LFB. The boiler plate on the valve cover will tell the truth. We all know that Kioti's website has been inaccurate and inconsistent at times.
Those hp and torque curve graphs are blurry and hard to read, they start at 1600 rpms and go to 2600 rpms at 100 rpm intervals.
To make things worse there is no graph for the 3a139LFB engine. Not sure why they wouldn't include this in that literature.
SKID STEER ATTACHMENT (A58214)
SKID STEER...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2006 Sterling Single Axle Road Tractor (A55272)
2006 Sterling...
2014 Toyota Camry Sedan (A56859)
2014 Toyota Camry...
10' Dump Truck Snow Plow (A55272)
10' Dump Truck...
Misc Pallet of Nails and Building Supplies (A57454)
Misc Pallet of...
