Pellet stove "sweet spot"
   / Pellet stove "sweet spot" #11
@ D33r3
Hi there... Sure, let's compare notes to see if we can identify an explanation for your observations on your Harmon XXV.
I suspect only two issues that could (temporarally) be resolved by a vacuum-only cleaning of the pellet stove as you have experienced. Specifically, clogged air holes in the burn-pot or combustion-air blower congestion.
While scraping the heat exchanger once a week is likely good practice and apt to keep operating efficiency high, it is not likely that a vacuum cleaning would significantly change the amount of deposits, and is not likely your issue.
It is also not likely that a clogged flue would be resolved by a vacuum cleaning. I brush-out my flue after each ton of pellets, but not likely your issue.
The stove is intellegent enough to vary its heat output based on how much it has to heat a room compared to the thermostat setting. Could be simply that some days it does not need to warm the room as much as other days. But you likely thought of that and are comparing similar flame sizes giving different heat outputs.
A vacuum could open partially clogged burn-pot air holes for a short time.
This seems to be a good possibility to explain your situation. Perhaps combustion does not start deep inside your burn pot, leaving very little room & time to burn fuel completely before it reaches the edge of the pot. Clean the burn pot holes all the way to the bottom of the pot - taking care not to poke at the fragile heating element directly under the holes. As mentioned - remove the cover under the burn pot and clean out ashes in that area. Procedure is described in the manual.
A vacuum could also partly open/clean the combuston air exhaust path and blower. that would be my second place to look and clean. Check the manual for that procedure.
Best of luck. Let us know how it goes!!
Greg.
I think I may not have conveyed my thoughts correctly.
When I do my weekly cleanup of the stove, I do the tips and tricks mentioned. What I'm saying is; several days after I clean it, the stove seems to be able to transfer the heat better from the inside of the stove to the room.
I haven't been able to put my finger on it and just wondered if anyone else had the same thoughts.
   / Pellet stove "sweet spot" #13
Toll, for lighting ours, we fill a gallon jar 3/4 full with pellets, then add about 1 cup of stove alcohol. Turn it over in the jar for around 15 min. Gives us months of alcohol damp pellets for lighting.
   / Pellet stove "sweet spot" #14
pay attention to your perceived heat output in relation to outside weather conditions.
Things like relative humidity etc and vastly change how the room "feels".
windy days can affect the draft of the stove which can affect the burn = heat output.
really cold days can pull more heat out of the house makeing the stove feel like its not running as hot (and vise versa)
2023 John Deere 333G for Parts (A55314)
2023 John Deere...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
Spirit scooter (A55787)
Spirit scooter...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
