Rotary Cutter Perfecting a new Rotary Cutter
   / Perfecting a new Rotary Cutter #11
My last truck took a set of bricks and logs into it and the pup chewed a seat belt off at before it turned 50 miles. I did the bricks just to get it over with. The dog doesn't like Scotchgard.
Instead of feeling bad, it actually relieved both our minds.
   / Perfecting a new Rotary Cutter #12
Oh my...:rolleyes::rolleyes::rolleyes:
Bill6, you need help... you just ain't right.
   / Perfecting a new Rotary Cutter #13
Not so outlandish ;) Here's how I clean my Bush Hog cutter.
After 2 years of hard use, I pressure washed it and stuck it in the shed for the winter.
Uh...no wax.
   / Perfecting a new Rotary Cutter #14
I do feel sorry for you wife!
Look you need to find something to do with your spare time ....................use the hog and clean it put it away.
That doesn't mean wash, wash, wash, wax and put it away in a heated garage.
Hope you are cutting flat leavel ground.
Wayne
..Nice job, Farm W Junk......but before storing it you should also touch up any paint scratches that might rust, and then wax the whole thing.
Anyway, with a clean & waxed tractor, it sure makes the whole package look nice when the implements are clean also. A clean tractor is a happy tractor!
   / Perfecting a new Rotary Cutter #16
WAX? On the Bush Hog? Uh...sure. The tractor stays clean, but the closest to bush hog gets to a rubdown is wearing the paint off of it while mowing.
   / Perfecting a new Rotary Cutter #17
One advantage of Bill's system is that he can stop in the middle of the day, raise the 3PT a bit, pull up a chair and eat lunch off the back of his cutter.
Of course he probably puts down a fine linen tablecloth first (which could explain part of the reason he is not allowed back in the house these days).
I imagine the bucket is just as clean which is a really good thing as that is where he sleeps.;)
   / Perfecting a new Rotary Cutter #18
BWAHAHAHAHAHAHA
   / Perfecting a new Rotary Cutter #19
My wife is from Kennewick. It must be all that radiation in the water.. Crazy as all get out those people...
Problem with all of this is there are no pictures.... Shame on you
Carl
   / Perfecting a new Rotary Cutter #20
I wonder the number, sizes, and capacities of his autoclaves. You know the ones he sterilizes his tools in prior to touching implements. Then there are the antibiotic additives to the fuel, the pump up sprayer of disinfectant to pre-clean the seat and steering wheel prior to touching it in case all the layers of surgical gloves fail at the same time.
I especially admire the huge array of industrial sized air wicks to kill all those pesky offensive lingering odors so prevalent in the rural venue.
Pat ;)
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2000 Sterling L9513 Winch Truck (A55315)
2000 Sterling...
CATERPILLAR 259D3 SKID STEER (A52707)
CATERPILLAR 259D3...
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
2017 Ford F-550 Stellar EC5000 2.5 Ton Crane Service Truck (A53422)
2017 Ford F-550...
