OP
Gale Hawkins
Super Member
- Joined
- Sep 20, 2009
- Messages
- 8,268
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
One more thing Gale, it's OK to flush the tranny through the cooler (fluid forward), but in our shop we always backflushed the cooler(s). It's not so bad in the radiator cooler, but the auxiliary cooler tends to collect bits and pieces that did not go forward and can reduce flow. Even with a backflushed aux cooler, we always recommended to the customer to replace the aux cooler after a rebuild. If they did not agree, we then put a filter on the return line at no cost. In the long run it saved US money. On a grenaded tranny, sometimes small pieces would collect in the coolers and then break loose later to cause problems.
Of course we used a pulsing air activated flusher for this purpose (knocks the particles loose).
I totally agree on the need to do a powered back flush of the ATF cooler(s) especially after a major failure of a transmission. As you stated this is really the only way to dislodge any solids pumped into it. The 2003 Escalade has a factory auxiliary cooler (tow package which I did not know they had for 2WD SUV's) but the 2002 Blazer does not.
Did the line filter need replacing after time or was it course enought where only the bigger stuff got trapped. I read more and more new ones only have a metal screen over the pump pickup opening.
I know the small shop did some kind of flushing because he said Jasper required it for the reasons you stated.
