Picked-up Free Murray!
   / Picked-up Free Murray! #11
Post back with the results. Also does it just spin slowly, or does it spin quick to a point and then "Hang up" like it's fighting the compression?
   / Picked-up Free Murray! #12
Wow, two years later still with the slow start Murray. :) So am I. I did find a bit more information about these mowers and this problem. It may not be the starter. Pull the spark plugs and see how it turns over. If it spins well then you should search the forums for another thread on this subject. The gist of it is that as the valve wear the valve gap gets larger causing the valve to open very late on the compression stroke. This means higher compression when starting which will bog the starter. I do believe that this is the problem with my Murray, but being an L head B&S engine there is no adjustment. One of these days I may tear it down and see if I can help things out by lapping the valves so they will seat a bit deeper and close the gap on the stem somewhat.
   / Picked-up Free Murray! #13
I see you paid full list !
Just spins slowly does not seem to hit a compression stroke. Previous owners siad it did this in the past but new battery always fixed it before. Not this time, that is why I am thinking electrical??
ya, i can spin it by hand too compression stroke then can't spin past!
   / Picked-up Free Murray! #17
When checking the clearances, I assume you just use a set of feeler guages? Where is the best (cheapest) place to get these?
   / Picked-up Free Murray! #18
Napa, Checker, Pep Boys, Carquest. It's all about the same.
Ok, also tried to supply direct battery voltage to the start terminals and it's can't spin it either?
   / Picked-up Free Murray! #20
Shortlid, the easiest way to see if it is the starter, is this way, It bypasses everything including any safety switches and switch, etc. You can use booster cables or a good battery charger. On the mower hook one positive cable to the post on the starter where your battery cable goes. Make sure you get the clamp on the nut on it and not on the threads of it. Make sure the cable is not touching anything else. Then all you have to do is touch the black cable from the booster cables or charger to a good ground on the engine. You do not want to use the hot cable for touching the post on your starter, because it may arc off and ruin the threads on your starter. If you can"t get a good grip with your cable on the starter, get a small pair of vise grips and clamp them on the nut on the starter, then clamp your red cable on them. Again make sure it touches nothing else. If your starter turns the engine fine like this, you will know the starter is good. If not then you need a new starter. The ground cable will arc off probably when you touch it to ground, so don"t ground it anywhere near the gas tank, or carb. Sounds like to me your starter is just dragging. You may be able to get it rebuilt by a starter or alternator shop. Good luck, zman Pete :D
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2020 KENWORTH T680...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
