Picking up Fibreglass water tank
   / Picking up Fibreglass water tank #11
I always thought a meter was about 39.4 inches.I guess you learn something new every day.
   / Picking up Fibreglass water tank #12
I obtained a fiberglass tank about 10 feet in diameter about 6 feet high, dome top. First, I drained about a foot of water out of it. Then was able to lever, carefully, one side up and block it with wood, then other sides.
To load it on a trailer, I used a bunch of 4 inch wide trailer straps to make a cradle for it going to a single lift point on top. Straps under it as well as a strap around the middle to keep them from slipping .I was fortunate that there was a BIG fork lift in the area, the kind used to lift bundles of shingles on top of a several story building. I talked the operator into loading the tank for me after work one day. Don't know how much it weighs, but not as light as plastic and not toooo heavy, either. Big problem was the bulk and need to lift from a single point high off the ground. That fork lift had no problem with it.
I need to move it again now. Do not have access to the fork lift. Am thinking I will block it up with wood, drive low boy flatbed trailer under it.
   / Picking up Fibreglass water tank #13
call the local septic tank company.. they should have a truck crane that can handle a 10' concrete tank.
dont see how its moveable with small equipment other than jacking it up and sliding a trailer under it.
That's what happens when I put a post up late at night. You are right 3 m is close to 10' not 18' which makes a huge difference.
You are right 1 m is equivalent to 39.4 inches, so 3 m is almost 10' not 18', sorry it was late when I put up the post.
Thanks, sounds like a good idea. My tank is 10' not 18'.
3000 GAL  SELF CONTAINED FUEL SKID (A52472)
3000 GAL SELF...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
JOHN DEERE LOT NUMBER 167 (A53084)
JOHN DEERE LOT...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
