Picture of the oil leak
   / Picture of the oil leak
If you need to block up the crankshaft, to take the houseing off, then what do you have the front of the tractor supported with? I was going to put a block under the oil pan to support it, while I split it, if I do decide to. I don't have a chain hoist or anyother way to do it.
   / Picture of the oil leak #12
You can split it the way you described. On my YM1110D, there is a plate bolted to the back of the engine, and the bell housing is bolted to this. That plate extends down lower than the oil pan. I probably removed the rear bolts from the pan, then put blocks under that plate. Removed the remaining bolts and pried off the pan. That should leave you enough access to prop the crank.
We are talking about 2 completely different engines here. Mine don't have such a plate like you are talking about.
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
Pallet of (5) 8 Lug Misc Wheels (A51573)
Pallet of (5) 8...
Airco Tig Welder (A51691)
Airco Tig Welder...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
