EddieWalker
Epic Contributor
I'm still amazed that bricks are used at the mound and home plate. There is engineering everywhere!!!
Do the bricks eventually dissolve?I'm still amazed that bricks are used at the mound and home plate. There is engineering everywhere!!!
Not really dissolve, but they will get worn down from the players shoes. If you look in the pics, you can see some loose clay in bags and in the batter's box. This loose clay is similar to the bricks, and is used below and above the bricks. It is also used to patch, or fill in, holes made by the players.Do the bricks eventually dissolve?
I grew up on a rice and soybean farm. After college I did research at LSU then worked for a large farm supply company. About 22 years ago I went on my own doing lawn care and landscaping. As time passed, I was doing more athletic field work and enjoyed it more than lawn care and landscaping.How did you get into this business?
What brand is the mower? Progressive? What is the advantage of a roller style finish mower? I would think the front roller would push the grass down inhibiting a good cut.Went work on some infields today. These fields are about 210 miles from my shop. And I have to go through Baton Rouge and New Orleans to get there. About 4 hours each way if the traffic is good.
First I mowed it down to the dirt.
The mower is a Trimax, which is similar to Progressive. The rollers allow the blades to follow the contours of the surface a little better. Although it does push the grass down a little, we use 'high lift' blades which will lift the grass for a better cut. The rollers also do a better job of striping the grass, which many people like to see.What brand is the mower? Progressive? What is the advantage of a roller style finish mower? I would think the front roller would push the grass down inhibiting a good cut.
That field looks entirely neglected.
