Pictures of home-made front-hoe
   / Pictures of home-made front-hoe #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
As promised (although 2 weeks late! /forums/images/graemlins/shocked.gif).
Here's 3 pics of the front hoe I built. (I didn't build the bucket, of course...I bought it last year.) The mounting plate is cut from 1/2" thick steel plate with a plasma cutter, the boom is 1/4" walled 4" square tubing, and I just replaced the 8" cylinder with a 12" cylinder (which required me to cut the tab that the end of the cylinder mounts to off and weld it back 4"). I welded the tabs onto the attachment plate using TIG, and most of the other welding was stick (nice that a TIG machine will also stick weld!) I get quite a bit more open/close travel with the longer stroke cylinder..I'm very pleased with it, and I think I can call it finished!
The thumb was made from the corners of the 1/2" plate that I cut off...good use of the scrap! I'll eventually have to replace the 1/4" plate that I welded the thumb to with something thicker...you can probably see from the photos that I've already bent it by picking up tree trunks.
Note that not only is the thumb really useful for picking up things like tree limbs and trunks, it also helps quite a bit with digging. The force of curling the bucket has the tendency to pull the tractor forward (even if the wheels are spinning against the pull)...jamming the thumb into the ground helps give it something to curl the bucket against, plus it helps break up the ground.
I am very, VERY pleased with this attachment. It was remarkable effective with the 8" cylinder...it should be even more so with the 12" cylinder on it.
Anyway, here's the first pic...full view of tractor with the front hoe.
Here's a close-up of the front hoe open...
And here's a close-up of the hoe closed. I'd actually wouldn't mind a little more travel, but a longer-stroke cylinder would be too long for the boom...I'd have to attach the cylinder to the top of the mounting plate rather than the boom, and that likely wouldn't be nearly as strong (the force would try to tear the boom off of the mounting plate!).
   / Pictures of home-made front-hoe #4
Dave -
That is just awesome!
I was wondering, especially with those who have the Lackender hoes, whether they have also noted any of the 'pivot pin' bending/breaking issues. I have the PT mini-hoe, and this weekend (barring inclement weather), we'll give it a good workout in the orchard.
Great job!
-Rob /forums/images/graemlins/grin.gif
I've updated my web-site with these photos. Also, you can see from the new picture of me on the left side of this post that I forgot to shave this morning... /forums/images/graemlins/wink.gif
Dave
   / Pictures of home-made front-hoe #6
Boy that sure is some mean looking hoe. If it works as good as it looks it will do the job easily. Are there no teeth on the bucket ?
So far, so good. Nope, no teeth...but it's an 8" inch bucket, so I doubt I really need teeth. I dug two ditches in the neighborhood with it so far...we'll see if I run into anything that it has difficulty with. So far, the toughest thing was a big root...the back end of the tractor popped up in the air while trying to rip it out. Took a few tries, but finally got it.
Btw, I also updated my web-site with pictures of the Selector Valve that I installed last year, plus the hydraulic schematic for it...
Dave
Oh, btw...I bought the 8" bucket from Northern Tool a couple of years ago...turns out it's manufactured by Lackender...go figure, right? /forums/images/graemlins/tongue.gif
Dave
You might notice one other oddity in the first picture...the solar panel on the hood. It's a 5 watt solar battery trickle charger (on sale at Harbor Freight for $39...I couldn't resist). Since several weeks can go by without running the tractor sometimes, the battery goes dead. So far, this solar panel has kept it charged. The hood is steel, so I've attached 4 small round welding magnets to the solar panel, and this holds it securely on the hood, even with vibration from the engine and bouncing around digging... /forums/images/graemlins/grin.gif
I love gadgets...er...uh...I mean...tools...as if you can't tell...
Dave
   / Pictures of home-made front-hoe #10
i like the design ..........i may have to build me on like that looks like it may be a wee bit more stout than the pt version
Woods RM660 3pt. Finish Mower (A50774)
Woods RM660 3pt...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
Pro Tech 16' Snowbox (A50774)
Pro Tech 16'...
2015 Hyundai Sonata Hybrid Sedan (A50324)
2015 Hyundai...
