Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #2,761
I'd check on the legality of studded tires. AFAIK, they're only legal for mail carriers in my area. I had a 1/2 ton truck, snow tires, limited slip, and of course 4-wheel drive. I did get stuck a couple times trying to push back akward banks. Other than that, it's a go-anywhere setup.
Got rid of the plow in favor of a 74" blower. Cut my snow clearing time in half. Arctic Carharts make up for the lack of cab/heat. =)
   / Pictures of your snow weapons #2,762
I actually plowed for two years with just the stock non-snows on! I was amazed at what I could do until I got stuck...then I got the studded ones. These were rated number one at the time...General Altimax Arctic...have not been stuck since and I've been in some awful places!
   / Pictures of your snow weapons #2,763
So, in trying to un-hook the plow for the first time I did some accidental back dragging on my driveway, and noticed that the plow doesn`t stay put... as in; started in V and ended in scoop. I do remember seeing something about cylinder lock as an option... what can you tell me about this?
   / Pictures of your snow weapons #2,764
I can't offer much help but to say check with a dealer and have your pump & plow model # with you. I think that they came out with "lock" to allow for back dragging, but I think that might be a function in the valve body, not the cyls. There are a few snow plowing sites - forums, where there are dealers and a lot of guy's that would know such things that would give you an answer, or maybe a cheap fix.
   / Pictures of your snow weapons #2,765
Boss has smart lock cylinders.....
Going by memory that you have a boss plow, so how that helps....
   / Pictures of your snow weapons #2,766
Going by memory that you have a boss plow, so hope that helps....
   / Pictures of your snow weapons #2,767
I hope I'm posting this link to my youtube correctly. This is a recent modification to my schulte 6200 that I've been running stock with the exception of the drift cutters that I added 8 years ago. It is not uncommon to get drifts in excess of 4' here. Have not run this mod in snow yet as we didn't get any snow last year. Normally we get quite a bit. I also started running ag tires 3 years ago and don't worry about getting stuck anymore. I have too many clients that wouldn't want me using chains on their driveways.
https://www.youtube.com/watch?v=of-ccD6kK_A
   / Pictures of your snow weapons #2,768
I'm looking forward to your second video. At first I was thinkning that you are going to need a shield across the rear of the blower to keep your top paddles from throwing the snow over the Schulte. But then I thought some more and figured if it wasn't turning that fast then it won't throw it too far anyways.
   / Pictures of your snow weapons #2,769
I thought about needing a shield early on in planning but agree with you that I probably will not need it. If I had one it would greatly block my view from the cab of debris ( branches, firewood, etc.)that might be present in the snow not to mention the neighbors cat. The first engine I put on it did not have the 6:1 gear reduction on it that it now has and ran much faster than I really wanted it too. It probably would have required a shield.
p.s. A piece of firewood will do a number on your auger.
   / Pictures of your snow weapons #2,770
Very cool... but wouldn't a piece of sheet metal running 45deg have been simpler? It would have just pushed the snow down to the auger.... even expanded steel so you can see through it would have probably done the trick...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
PALLET OF MERITOR BRAKE SHOES (A55745)
PALLET OF MERITOR...
PALLET OF (2) HEATERS (A55745)
PALLET OF (2)...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Miller Legend AEAD-200 LE Towable Welder Generator (A55851)
Miller Legend...
