Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,011
Wow !! are you sure your tractor is powerful enough to push that thing full of snow. That is a big snow pusher.
44 hp gross, 42 net, four cylinder. It does my hills in high gear too :)
I love this mule as it has load sense & linked throttle to HST.
I will not know until winter if I have enough traction...using back blade and retaining wall bricks for rear ballast 800#.
Prime says the snow pusher only weighs 625# but it looks heavier..lol
   / Pictures of your snow weapons #5,012
That pusher looks HUGE! The PO sure took good care of that tractor.
2012 with 187 hrs on it when I purchased. :)
   / Pictures of your snow weapons #5,013
no one else saw the big block V8 snow blower?. THAT is HUGE!.. it comes with either wheels or tracks..
   / Pictures of your snow weapons #5,014
I guess we will have to wait till winter to know for sure. Let us know then how it performs
   / Pictures of your snow weapons #5,015
I think the tractor will push it. The weight is probably similar to my 8' Fisher plow setup. I have grooved the tires, and it makes a difference in traction. This is the second tractor with R4's that I've grooved. I haven't had a real pusher, but did add wings to the loader on my L3200. It worked OK.
The one drawback was that it would only move snow in pretty much a straight line. For short runs it was fine. I do parking lots at the church and the thing would fill and spill before getting to the end of the lot if I took wide bites.
With the angling plow, I can drive the length of the lot casting snow to the side and clear the whole lot working from one side to the other. For driveways I can get close to the garage doors and backdrag away from them.
   / Pictures of your snow weapons #5,016
I push with a hydrostatic 3038e, 6ft snow pusher. Set the rubber blade 3/8" above the shoes and it catches no gravel, dream to use.
No problem on stock R4's running 16 psi in the rears, and 750lbs 3pt Ballast.
   / Pictures of your snow weapons #5,017
Running it that high off the surface, and never scraping do you run into the problem of having such a thick base of snow that in the spring it turns into a solid sheet of ice when things start warming up during the day and freezing at night?
   / Pictures of your snow weapons #5,018
No not at all, the push weighs about 800lbs, it usually cuts trough right through to the bottom. In the spring i have about 1" of hardpack over the grass. As soon as the spring sun hits it, it disappears pretty quick.
I get zero gravel in my snow piles.
But also i live in Alberta Canada, Global warming has not come here yet.:laughing:
   / Pictures of your snow weapons #5,019
Yeah, you're lucky up there, you get a real winter and can establish a thin plow base (I happen to like snow and cold, which not everyone agrees with). I'm in a part of VA where we can get decent snow falls, but there will almost always be a thaw within a week. Sometimes the thaw happens the very next day!
   / Pictures of your snow weapons #5,020
Here is what I’ve used last 4 to 6 years and here is my new one.
Jim.
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
Ryobi Sliding Compound Miter Saw (A54865)
Ryobi Sliding...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
2008 INTERNATIONAL 9200I DAYCAB (A55745)
2008 INTERNATIONAL...
