Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #581
It's funny you mention that. I have a friend who works as a foreman on a large construction company and they do condominium complex snow removal-BIG TIME stuff. They have 1 Honda tracked snowblower, like 32" wide. He said "it went through a shear pin an hour" I think was how he described it. Said he finally gave up and brought a different brand of bolt.
My gravel is mixed with some pretty course stuff from over the years. I had a piece of inch and a half stuck in there good, can't blame the machine this time, it gets stirred up by the tractor and my buddy's plow.. I really should just save it till I put a good top layer down.
   / Pictures of your snow weapons #583
I pretty much gave up using mine for for a few years, maybe forever with any luck. Had to replace an auger gearbox last year after it ingested a good sized rock. The shear bolts help, but there's still a good shock load when it breaks one.
Sean
   / Pictures of your snow weapons #584
About 14 inches here since last evening.
Finally got to try out the snowblower on the Massey:thumbsup:
Nice storm accumulation.
Were you totally satisfied with your blower.??
I love mine so far.!!:thumbsup:
   / Pictures of your snow weapons #585
Sears LT 1000 "SE" under construction but had to play in the last snowstorm.
My new favorite snow weapon! :thumbsup:
Did I miss the build thread on that one?
   / Pictures of your snow weapons #586
I have not done a proper build thread. I did post some pics of its progress in the welding section. I started a thread on another site but the progress is slow going. The thread had intial interest but faded fast so I am not bothering to waste my time updating it. Do you think it would get a better response here ?
   / Pictures of your snow weapons #587
At least point folks to the welding thread... I was enjoying the read.
   / Pictures of your snow weapons #588
I know I would like to see it. I've seen some similarly creative threads really take off in the "Build it Yourself" section. I love seeing how other members create and solve problems, and we all like spending other people's money.
So how does that monster do in the snow? Is it 4 wheel drive? Can you push a lot of snow before you overpower your traction? What's the turning radius?
   / Pictures of your snow weapons #590
I am continuing with progress pics so once it is completed then I will do a thread in the building section.I think it will be better to show it all at once rather than a piece at a time.
It is AWD,articulating and oscillates 15 degrees ( I can put opposite corner tires on 7" blocks) and has a 28" turning radius . With the plow on I can easily turn around within the width of a one car drive. It is traction limited with the turf tires but it still can plow 6"deep snow with ease. The tires need to be filled and I will put on v-bar chains then I will be able to see what it can do.
A small FEL w/grapple is under construction now along with rear 3pt,dual batteries,inverter, 8 gpm gear pump for FEL. Currently the hydraulic steering and plow lift/angle are run of the axles aux pump.
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
