Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,391
Question for grs and the others. Will the pump circuit on a Kubota B26TLB with the factory disconnects for the backhoe, run a front snow blower on the loader arms? The tractor has a rear pto that I could use after I take the backhoe off. (Or leave it on for traction.) But the front blower is much nicer. The other option would be to use a rear pull behind blower. Which would be less expensive? Just wondering. I now use a BX2230 with a front blower and a cab, but with a 3/8 mile long drive and 4 passes to clear it, it takes a bit of time. Thanks, Jon
Need more hp than 25-30 hp.
   / Pictures of your snow weapons #5,392
Smaller tractors that have mid mount pto operate subframe front blowers ok, but I believe it’s a minimum of 40 hp for rear powerpack if I recall
   / Pictures of your snow weapons #5,393
Is there a minimum HP for a rear inverted blower? Jon
   / Pictures of your snow weapons #5,394
Meteor shows 25 hp for the 5' pull type snowblower.
MK Martin | Meteor Pull Type
Thinking my 7' front mount blade is a lot faster to clear off snow (I've no problem pushing snow to the side), no clean-up of snow when parking in shed, no moving parts, and smaller footprint to store for summer time.
But still looking at them... :)
   / Pictures of your snow weapons #5,395
You're right about the front blade. I used rear blades, two different front blades and a rear blower over the years.
   / Pictures of your snow weapons #5,396
There is no one perfect show removal implement. What I really want is:
  • UTV with a 6' snow plow
  • 25hp - 35hp CUT with a front mount snowblower
  • 40hp - 60hp CUT with a loader and inverted snowblower
  • 3/4 ton Pickup with snowplow
  • Full size Articulated Loader with oversized bucket and front blade
  • Pole building for all of the above
   / Pictures of your snow weapons #5,397
The sun :laughing:
   / Pictures of your snow weapons #5,398
:thumbsup: You got that right, most people need several tools, not just one, to get the job done. I have 6' blade on a 6x6....
   / Pictures of your snow weapons #5,399
All of the above for $1.00. Don't you wish! Jon
   / Pictures of your snow weapons #5,400
10415614_10152551250269369_7572261398592358407_n.jpgIMG_20151121_085700863_HDR.jpgIMG_20190310_154830135~2.jpg
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2357 (A58376)
2357 (A58376)
2003 Big Tex 10PI...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
Heavy Duty Skid Steer Breaker (New/Unused)(Est. Retail Value $4,800). (A59225)
Heavy Duty Skid...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
