LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,184
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Nice setup.
Nice looking rig! How did you fasten the front fenders?
Very nice. :thumbsup:
We use tractors with frame mount plows also and have found that we can give the customers a better job, faster than a pickup (visibility and maneuverability) even with the much slower travel speeds. And we're not talking about subdivision plowing either. And then there's also the NEVER getting stuck part. :cool2:
Thanks! they are fastened by a plate that connects to 4 of the 10 mm (i think) bolts that hold on the axle shaft housing as well as 2 maybe 15mm? bolts for the top bearing housing. Ive stood on em many times and they support my 200lbs just fine.
Sweet. I didn't notice the fenders in your first photo. I gave up on buying fenders, even though they are supposedly and option on the L60 series in Canada.
I should try my poor welding skills and fab a set up.
For some reason, they are way more available in Canada then here in Michigan. We had to call all over the place to even find a dealer that could get em. If you decide to build a set, the only thing i'd say to be careful of is that when the axle is articulated and the wheel turned to full lock, there is very little clearance between the loader frame so they have to be built very tight to the tires. Mine actually just scratches up the paint if they get fully articulated. and as mentioned before, I basically used one cheap trailer fender that i picked up at tsc and cut it in half and then down the middle to widen it with some 1/8" plate. Its really not to bad of a project since you can just start at the axle and work your way out.
All of the larger farm tractors require readjusting the travel stops when adding fenders on the front axles,
to prevent the fenders from contacting the frames.
