Pictures or description of Kubota draft control??
   / Pictures or description of Kubota draft control?? #1
4x4sche
Western WA.
Kubota L5030 (50hp)
Has anyone got option L8312 "draft control" on their L30 series tractor? I assume that it works on the top link. Can you post some pictures.
I am planning to use this option to allow me to build a land plane that automatically adjusts the scraper height as the tractor goes over bumps and dips.
   / Pictures or description of Kubota draft control?? #2
"draft control" usually (used to anyway) applies to ground engaging attachments, such as a moldboard plow. It senses the compression force on the top link, and when that force exceeds a set level, then the 3pt arms are raised until that force goes below the set point.
At least that is the way 'draft control' used to function. Maybe now there is a different meaning to 'draft control' that would do what you are wanting to do.
I wish you good luck and hope it works out well.
You are correct in your understanding of draft control. I plan to modify the Kubota kit to my purpose.
Pictures anyone?
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
2006 Big Tow BE-5BL (A47477)
2006 Big Tow...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
John Deere 7130 (A53314)
John Deere 7130...
