Pictures or description of Kubota draft control??
   / Pictures or description of Kubota draft control?? #1
4x4sche
Western WA.
Kubota L5030 (50hp)
Has anyone got option L8312 "draft control" on their L30 series tractor? I assume that it works on the top link. Can you post some pictures.
I am planning to use this option to allow me to build a land plane that automatically adjusts the scraper height as the tractor goes over bumps and dips.
   / Pictures or description of Kubota draft control?? #2
"draft control" usually (used to anyway) applies to ground engaging attachments, such as a moldboard plow. It senses the compression force on the top link, and when that force exceeds a set level, then the 3pt arms are raised until that force goes below the set point.
At least that is the way 'draft control' used to function. Maybe now there is a different meaning to 'draft control' that would do what you are wanting to do.
I wish you good luck and hope it works out well.
You are correct in your understanding of draft control. I plan to modify the Kubota kit to my purpose.
Pictures anyone?
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
Pallet Of Mini Excavator Attachments (A47477)
Pallet Of Mini...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
