Pine Trees Dying
/ Pine Trees Dying #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
We have found several Southern Pine trees on our property that appear to just up-and-died for no reason. Some are small saplings and others 30-feet mature trees.
I am somewhat familiar with Pine Beetle problem and I can see no bore holes or any other fungi or reason they have died. I noticed the first ones in Mid-August and I attributed it to the dry conditions. Oddly, there are healthy pines right next to the dying ones. Today the wife and I walked around the property and counted 20+ trees that are dead or dying. Needles fall of the branches when touched like they have been dead for months.
Any ideas? All the trees were one reason we bought the property and I would hate to lose more especially if there is something I could do.
Most likely contact the extension office next week but would also like to hear your thoughts. TIA
/ Pine Trees Dying #2
I'm not familiar with southern pine or your area. But here in BC we've had severe pine beetle kill. You don't see bore holes. The beetles aren't impressive. They are about the size of a grain of rice.
Once the pine starts to turn brown it is already too late. We had them go through here a couple of years ago. I never knew we had so many pines. But some pines, particularly the younger ones, survive.
I've also been told that a dry season can make it worse. If trees have lots of moisture they will force the beetles out by making pitch.
We have plenty of trees and varied species so it isn't too bad. We had a few we wanted to save along the driveway and put up those natural patches that make the bugs think the tree is already too populated. They were expensive and I'm not sure they worked. So died, others didn't.
If there are pine beetles in your area I'd would suspect that. You can see them advance each year. But I think once they are done things will come back in a while.
A troubling thing here now is that they are saying some kind of beetles may be attacking the firs.
/ Pine Trees Dying #3
my guess is pine beetles. I'm having the same problem. By the time you notice the damage, it's too late. I'm in the process of treating the other trees but, the beetles may have already damaged the live trees
/ Pine Trees Dying #4
I seem to recall that if the tree turns brown from the top down it is the beetle that is the problem. Don't know if this is true or if it is something I just dreamed up. We had several pines in a row that died like this. Really hated to lose them because they formed a nice barrier between our house and the road.
/ Pine Trees Dying #5
Most pine beetle infestations occur when the tree or trees are subjected to stress. Drought, thinning, sudden exposure to increased sunlight after thinning, damage to trees by mowers or equipment are some possible causes. Root rot and even mites can also kill a tree. Your County Extension Office will most definitely supply you with more detailed info in regards to your problem. Good Luck.
/ Pine Trees Dying
That is interesting because the ones I did notice started turning brown at the top.
Pine beetle kills that I have been shown the bore holes were obvious, about an 1/8" hole with sap leaking out. Could be we have some stealth beetles at work.
Any recomendations for treating the healthy trees? Natural or chemical?
/ Pine Trees Dying #7
/ Pine Trees Dying #9
Did you spread lime on that area? Pine trees dont like lime and enough of it will kill then.
/ Pine Trees Dying #10
During very dry (stressful) summers, Ips pine bark beetles can be bad and they normally attack high in the tree. Again, in dry years you may not see much pitch resin. Fell a tree and look under the bark.
Ips Bark Beetles in the South - FIDL
2013 Ram 1500 Pickup Truck, VIN # 1C6RR6GP1DS541918 (A61165)
2013 Ram 1500...
GENIE SUPER LIFT CONTRACTOR (A60736)
GENIE SUPER LIFT...
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
SD Lanch SDLD25 (A60463)
SD Lanch SDLD25...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2018 Bobcat T650 (A60462)
2018 Bobcat T650...
