pins for hitch receiver/ball mount?
   / pins for hitch receiver/ball mount? #11
Yup when they rust in there good they are not coming out. We tryed to get one out, heated the hitch cherry red, the insert still wouldn't move with a 10 lb sledge. The one in our car did come out this way but it was only a 1" insert.
I was gonna say just leave it in for 2-3 years, you wont have to worry about it getting stolen :laughing:
With all those pull pins it might be tempting to a kid like you say, My bike carrier has a special allen bolt with a raised section in the middle that requires a allen wrench with a hole in the center. just don't lose that special wrench/ key.
I agree though maybe just replace with bolts.
JB
   / pins for hitch receiver/ball mount? #12
I just use a couple of the locking hitch pins, like the one shown adjacent to the picture of the hitch on the link page.
   / pins for hitch receiver/ball mount? #13
I have the same hitch and the same concerns you do. I don't leave the hitch in all the time but there are places I go where I worry if some curious kid or some wise ***** won't mess with the pins and I end up losing half the hitch when not trailering or maybe a load if I do have a trailer connected. So I am doubly sure to visually check the hitch condition before I start out each time.
To lock it up you'd need three hitch locks and then you would have three keys to keep fumble through when you need to adjust the hitch height. To remove the hitch from the truck only one lock. If you color coded the keys to the locks or marked them in some other way to make identification easier it might take away some of that pain. If you do get locks then be sure they are rated for the MAX load of the hitch or better. A set of hitch locks keyed alike would be nice but probably hard to find.
   / pins for hitch receiver/ball mount? #14
I too just bought one of these hitches, so far very pleased. If I am not mistaken they make a locking pin kit. I am also concerned about theft so for now I simply put in the anti rattle bolt they supply with the kit, the one that srews in from the back with an allen wrench, and tightened it pretty hard. Someone can pull the clips but they cannot remove the pins without some tools. I am going to check out the locking pin kit for an more convenient solution though.
   / pins for hitch receiver/ball mount? #15
You could use some grade 8 bolts instead of the pins.
+1
If they're walking around with a wrench set, you're sort of done anyway you look at it.
I'd use the nylon anti-vibe nuts and try to find them the same dimension across the flats as the bolt head. That way you can curse me when you can't locate two 9/16" wrenches in a hurry.
   / pins for hitch receiver/ball mount? #16
I have one of these on my pintle /ball combo and once it's a little boogered up, they are a PITA to remove. might prevent someone from just casually tampering with it.
5/8 inch One-Piece Hitch Pin PMP-7520
JB
   / pins for hitch receiver/ball mount? #17
+1 on using a receiver hitch locking pin in at least one of the holes. Also, brush all of the pins with some Fluid Film before installing them and they won't seize in place.
   / pins for hitch receiver/ball mount? #18
EDIT: I did see a lot of receiver locks online, but I don't really want a lock that is going to get stuck on me at an inconvenient time! :)
I've had one of the Master Lock units on my truck for 10 years now and I haven't had any problems with it. The rubber cover over the key slot and a O ring where the lock portion attaches to the pin keeps water and dirt out.
Here's the one I have.
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
International Bucket (A55973)
International...
PALLET OF MISC HOSE & PIPE INSULATION (A58374)
PALLET OF MISC...
536 (A52708)
536 (A52708)
401 (A52706)
401 (A52706)
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
