Pipe connectors for carport?
   / Pipe connectors for carport? #1
Westonium
Chehalem Mountain area, OR
JD 4310
Has anyone been able to find a source for 2" steel pipe connectors for the purposes of making a carport etc?
My lame tarped carport elcheapo special is coming apart, rusting, and the tarp is toast. The white paint on the pipes is eroding and leaving white marks on the vehicles parked under it.
I've seen several kit carports that use galv steel pipe and they look like I could easily build something similar if someone sold just the odd connectors required.
Surely there are a few companies out there that make these sorts of things.
   / Pipe connectors for carport? #2
I wouldn't bother going to try & make one, they are dirt cheap at a lot of ploaces generally cheaper than attempting to source all the parts, make them work and then get the stuff for it built.
go to TractorByNet.com | John Deere, Kubota, New Holland, and more! for a good price
also try harbor freight and homier traveling tool show on-line. other source would be pep boys and jc whitney.
hope you can get what you need there.
Mark M
   / Pipe connectors for carport? #3
I agree w/ spiker. There are a couple guys that sell those tarp/pole kits and parts at the local flea markets. I can buy their parts and kits WAY cheaper than hunting it down from metal suppliers strangely enough. Also.. Harbor freight, Kmart, and TSC have some darn cheap 10/12' x 20' kits ... ( tarps are cheap at the chinese store. And I buy the cheap ones.. I usually get about 2 ys from them in the fl sun and wind. Same with an expensive tarp.. etc.. I've tried both.. etc..
I've got tens of thousands of dollars worth of tractor an implement parked out in the apsture under tarp structures... way cheaper than adidng on to the barn...
Soundguy
Thing is, I already have 3 tarp "garages and they've been TERRIBLE.
The white paint on the tubes leaves residue on vehicles, the poles dent with a stern gaze, etc.
If I can get something as a kit that has a sturdy steel frame for cheap then I am interested. I'll check that link now.
Any other suggestions?
   / Pipe connectors for carport? #5
The ones I have are galvanized, and look more like the top rail on a chain link fence. It's thin wall.. but doesn't sound like it is as thin as yours.
Soundguy
   / Pipe connectors for carport? #6
i have a greenhouse that is framed using EMT and the frame holds up very well.
   / Pipe connectors for carport? #9
Costco has the whole package for $168.00.
Harris
   / Pipe connectors for carport? #10
There is a large selection at TekSupply; greenhouses, tension fabric buildings, agricultural supplies, truss arch buildings, barn curtain, building supplies, doors, hardware. called "Quik Klamps" and they seem to run from $4 to $7 each, depending on size and style. They have sizes from one inch, one and a quarter inches and one and a half inches.
I don't know anythinb about this company, they just send me catalogs, but from the pictures, they look like industrial grade clamps that you could use for railings, shelving and just about anything you'd want to make out of pipe.
Good luck,
Eddie
   / Pipe connectors for carport? #11
A local muffler shop manager made a carport using tailpipe material bent rafters and socketed together then welded. He got the material wholesale but its an idea anyway. Find someone local with a press (a junkyard) and get a quote to bend up EMT tubing you supply from Home Depot, then find a local welder (a shop teacher maybe) to tack it all together.
But it will be hard to compete with the price of those complete kits.
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
Auger Skid Steer Attachment with Bits (A59228)
Auger Skid Steer...
CATERPILLAR 262D SKID STEER (A60429)
CATERPILLAR 262D...
