Pitted Cylinder Rod: Repair or Replace
   / Pitted Cylinder Rod: Repair or Replace #21
Talked to a local shop.
For less than I could buy a new rod and seals (which are around $350) - actually about $75 less, they made from stock a new rod, and replaced the seals. They also had the right tools to remove and reassemble the cap - to keep me from destroying it...
This includes a 1 year warranty on parts.
Now to get the thing back together.
Good decision. That was the best possible repair for a very decent price. Anything else would be a bandaid that would come back and bite you.:thumbsup:
   / Pitted Cylinder Rod: Repair or Replace #22
Sounds like he decided to do the repair the correct way, spent the moeny and let a shop do it for him. I do have a shadetree suggestion for someone else in a similar position.
With a pitted rod, just cleaning it up with emory cloth will get you back to running, altho it will probably leak some. Alternative solution, the leaking comes from the pits as they past the seal, provided you didnt ruin the seal by running the shaft in and out before you cleaned it up with the emory cloth first. A good temportay fix that pretty much stops the leaks from the pits is to fill the pits. This can be done by emory cloth first, an application of phosporic acid to stop the rust and act as a metal prep for paint, and then a simple coat of an epoxy paint, such as POR 15. After the epoxy paint dries, hit the shaft again with the emory cloth until all you can see is shiny metal and the pit spots that are now filled with a super hard epoxy. This will pretty much stops the leaking, unless the seal was also damaged. A cheap fix that just requires a little elbow grease. You will find the epoxy paint super hard to sand and it isnt effected by the hydraulic oil so it will stay put without peeling as long as you took the time to do the proper prep work first. This maynot be the proper fix, but if you aint got the money to do the job the right way, this method will get you out of a bind.
   / Pitted Cylinder Rod: Repair or Replace #23
I have a simlar cheepy fix for a pitted rod . not sayin it right but can help when you cant fix it right. about the same as above only sand and clean the rod . use jb weld to fill the pits and sand down smooth when it sets up. I have used this methed a number of times with good results.
   / Pitted Cylinder Rod: Repair or Replace #24
Like I said above, I did mine with a brillo soap pad back in 1999. Driven a thousand or so posts. Still working fine. I have necessary work to spend $ and time on..
larry
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
1264 (A50490)
1264 (A50490)
TMA (A49461)
TMA (A49461)
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
