Pivot Fixture on Backhoe
   / Pivot Fixture on Backhoe #1
JWD1312
CHEYENNE, WYOMING
Kubota 7510
I have plans for the caddigger 841 but I don't like the pivot fixture using the brass thrust bearings. MY question is how would half of a I-beam front axle (using the ball joints too) off a very big truck work for the fixture. ALso anyone have info on the ubuildit Ground Hawg backhoe any problems they might have.
   / Pivot Fixture on Backhoe #2
I serched Google and You will find what Jim Steeby did here…
http://www.metalwebnews.com/howto/caddigger/caddigger.html
He also invites email so you could check with someone that has built one and modified it…. Welcome to TBN /forums/images/graemlins/laugh.gif, should be getting cool where you are about now /forums/images/graemlins/smile.gif.KennyV.
   / Pivot Fixture on Backhoe #3
big trucks dont use balljoints so scrap that idea. myself personaly i dont see whats wrong with plain bushings, thats what most large backhoes use, keep them greased and they are good for thousands of hours
   / Pivot Fixture on Backhoe #4
This is true, they don't use ball joints they use 'king pins' which is basicly the same as a back hoe uses just cut off the wheel spindle an go from there, should be strong enough to work.
   / Pivot Fixture on Backhoe #5
why bother using a king pin setup, they have bronze bushings just like the original design, ya might as well just build it the way they designed it
   / Pivot Fixture on Backhoe #6
Usaually cheaper, and then there is the challenge to see if you can make it work without buying it off the shelf /forums/images/graemlins/confused.gif /forums/images/graemlins/laugh.gif
2019 Nissan Titan 4x4 Crew Cab Pickup Truck (A44572)
2019 Nissan Titan...
2001 Winnebago Chieftain WFL36W Class A Motorhome (A44572)
2001 Winnebago...
16ft Enclosed Trailer (A44571)
16ft Enclosed...
1989 Miller 28' Tomato Trailer (A44502)
1989 Miller 28'...
2023 MAC TNAR42NF0 42FT PNEUMATIC TRAILER (A43005)
2023 MAC TNAR42NF0...
2015 Chevrolet Malibu Sedan (A44572)
2015 Chevrolet...
