Planer help needed
   / Planer help needed #11
</font><font color="blue" class="small">( Why does he have to join it?? )</font>
Well, if you want a flat board, you joint one side, then plane the other. You can't remove bow, cup or twist any other way. A planer pushes the board flat on to the table and gives you even thickness (thus the name thickness planer). If the board goes in twisted, it will come out twisted, just with even thickness.
Cliff
   / Planer help needed #12
Try looking at the websites for Fine Woodworking magazine or American Woodworker. I know both of them have run reviews of planers in the past so you might be able to dig up some "professional" opinions of the options that are out there.
Fine Woodworking:
http://www.taunton.com/finewoodworking/index.asp
American Woodworker
http://www.rd.com/americanwoodworker/action.do?categoryId=7000&siteId=2222
I have a 12" Dewalt Planer that has worked very well for me during the construction of my house. I have also used Powermatic and Delta tools and their stuff is very good also. Try doing a search on Amazon.com under Tools & Hardware for planer and you will get a lot of results. Amazon lets buyers put in reviews so you can get some good feedback there. I think if it was me and I was in the same situation I would take a hard look at the Powermatic - 5HP, 230volt/1ph.
   / Planer help needed #13
</font><font color="blue" class="small">( . . . go on the foresty forum boards. Those guys on those boards are a wealth of imformation just waiting to share it with someone. )</font>
Deerlope,
Can you give me the website for the forestry boards?
Thanks,
Eddie
   / Planer help needed #17
Egon,
Thanks, there's allot of information on that site, looks like fun.
Eddie
   / Planer help needed #18
Hi Glenn,
I think you have some very good recomendations from some of my fellow woodworkers. Just by listening to you on the amount of lumber that needs to eventually be joined and planed, you are going to want a pretty substantial machine.
I presently use a 15" Grizzly that works fine for my occasional project. If I was using it more often and running large amounts of lumber through it I would have the carbide knives on it.
Another thing that I didnt hear anyone talk about is that, properly covered that lumber wont go bad, you just need to keep it dry and it will last forever.
As Cliff mentioned, you will also need a joiner to get the boards flat. I presently use a 8" Delta, that works quite well, but obviously your limited to 8" wide lumber. I would be glad to help with any other questions.
scotty
   / Planer help needed #19
I would be careful about covering it up until its planed/dryed,blue stain,or other fungi can set in.lumber needs to breath.ALAN
I believe he meant to keep it protected from direct sunlight and rainfall. If it's covered and has good air circulation those things won't be a problem.
As they cut they'll stack and cover. As they progress with the cutting what is stacked/covered will be drying. Eventually they'll get around to planing after the lumber has dried, and stack and cover it.
The amount of timber that's been blown down in the southeast states is hard to imagine. My step-dad is one that's going to try his best to not let anything just go to waste, and he's eighty years old (with a son-in-law helping him). Due to health issues with my wife, I can't be there. I started this thread in an effort to get information regarding machines to plane lumber, other than lunch-box portable planers that I've used. I appreciate all the responses.
Pull-Behind Smooth Drum Ballast Roller (A52377)
Pull-Behind Smooth...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
