planning stages for a grapple
   / planning stages for a grapple #1
kacole
gaffney, sc
kubota mx5100
I'm in the planning stages for a 72" grapple. I've been looking around and it really don't look that tough for a good welder/fabricator. My main question is how thick should the tines be? how long should they be? how high should they be? I guess it will be made out of A36 steel because it's easy to get. is that a mistake? I was thinking 1/2" thick but i don't want to make it a overkill but i don't want it to be easy to bend either. would like it to be plenty heavy enough but not take too much from the tractors lifting. the tractor will be a Kubota mx5100 thanks for the help
   / planning stages for a grapple #2
Kacole,
I'm right there with you.....I've already cut my templates out. I'm planning on going with 3/8" on the tines in A36 steel. I don't have a torch to cut the material but I did find a company w/in 12 miles that can water jet cut my materials. I just have to get my templates in a "cad" file for them. So, I'm stalled until I do that. I'm planning on a 50" wide unit w/ a single lid....what are your plans? I can get a sheet (4x8) of 3/8" A36 for $250. The company I'm talking with said they have plenty of surplus and said they'd make me a deal on it.....time will tell.
I'm planning on 72" with 2 lids how much are they gonna charge you to cut them on the water jet there's a place not too far from me that has a water jet but I didn't know how much to expect to pay.I figures if it was too high I would just use a torch. Also how long are you planning to make your tines
   / planning stages for a grapple #4
Some places charge per inch, some charge per hour. I'd rather get an inch quote as you can't mess that up with poor operator management (they can't fudge their time).
   / planning stages for a grapple #5
Here is a good design that you can get some ideas from.
Notice the high pivot point for the lids, this is why it has a 51" opening, great for picking up brush.
The tines are 1/2" thick.
   / planning stages for a grapple #6
That picture sure showes a good bite. How much can a tool cat pick? Does this force you to drive backwards?Very good looking. Would you make any changes?
   / planning stages for a grapple #7
Hey guys I was wondering what your opinions are concerning the ends of the tines? In all of the above photos posted by Xfaxman the tines are pointed upward. What are the advantages of pointing them upward vs having them point down? Other then digging into the earth I'm wondering if they were pointed downward brush, branches etc. could roll into the grapple easier? Your thoughts. Stanley
   / planning stages for a grapple #8
I would think that you choose the angle when picking the pile and when curling back the tips keep the items in it's grip.
I think the pictures will help in the planning the one in the pic is made out of flat bar a lot of them has the tines cut from one solid piece is there any advantage making them from one piece?
   / planning stages for a grapple #10
You might want to reconsider the width. I've got a 84" grapple on my M9540 and there are times I wish it was narrower. 72" seems like a lot of grapple for a mx5100.
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2002-2004 CAT 325C Excavator (A59213)
2002-2004 CAT 325C...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
(1) 4" X 153" CHANNEL IRON (A58375)
(1) 4" X 153"...
2018 Toro Reel Master 5510-D Fairway Reel Commercial Mower (A56857)
2018 Toro Reel...
GEARMATIC WINCH CABLE DRUM (A58216)
GEARMATIC WINCH...
