Planting Sunflowers
   / Planting Sunflowers #11
Sounds like the deer must have eaten the leaves? What tracks were left around them?
   / Planting Sunflowers #12
On a dry season grasshoppers will strip acres a day .
   / Planting Sunflowers #13
I disked my field and broadcast the seeds, then draged the dirt smooth to cover them. They start to sprout within a week. I bought black oil sunflower seeds for bird feeders. They come up about three feet tall and look real pretty. I do it for photography reasons. I was hoping the deer would eat them, but I didn't see any evidence of that last year. This year I did it a couple weeks ago and I'm seeing them starting to come up nicely. I have red clay soil, which seems to be good for them. When the drought came, they lasted quite awhile, but where all dead and gone by mid summer. We had almost three months of 100 degree temps and no rain. I'm hoping that this year it will be better and they last longer, but as long as I get good pics before summer hits, I'll be very happy.
Eddie
   / Planting Sunflowers #14
Where does one purchase that quantity of sunflower seeds and how much would it cost to do a few acres (3 or 4)?
   / Planting Sunflowers #15
You can buy oilseed sunflower seed, sold as bird seed in most stores. One of the ag stores near here will sell you as many pounds as you want. I just get the birdseed variety, germination was good for me. The deer liked them too much, didn't get to see many flowers. Mark
Cut and paste from University of Missouri Extension.
Planting
The most critical planting requirements are getting the seed into adequate soil moisture and choosing an appropriate seeding rate. Planting date and row widths can vary considerably without seriously affecting production. For heavy soils, seeding depth should be 1 to 1.5 inches, depending on depth to moisture.
Seeding rate is especially important for sunflower varieties intended for the snack food market. A high seeding rate will cause seed to be smaller, which is undesirable for snack food. A general recommendation for this type of sunflower is 17,000 seeds per acre (roughly 4 pounds per acre), while a general recommendation rate for oilseed varieties is 23,000 seeds per acre (roughly 3 pounds per acre). The higher seeding rate is recommended for oilseed types to improve yields. Seed size will be reduced, but market prices for oilseed sunflower are unaffected by seed size.
Yields from April or May plantings normally will be higher than June or July plantings. Sunflower can germinate and emerge from soils as cool as 46 degrees Fahrenheit if the seed is of good quality. Frost will not cause long-term damage until plants are around the six-leaf stage, which is normally after the danger of frost has passed. Mature sunflower also tolerates low temperatures, being able to withstand temperatures down to 25 degrees Fahrenheit.
Row spacings should be wide enough to permit cultivation, typically 20 to 30 inches. Various row spacings show little effect on yield, except that dwarf sunflower will close a canopy better and yield more when rows are less than 30 inches apart. Row orientation is another factor often debated for sunflower. Research has shown no yield difference among possible row orientations, but some have suggested that a north-south row orientation can make harvesting easier.
A common planting method is to equip a corn planter with special sunflower seed plates, which are sold by various companies. A fungicide seed treatment prior to planting is often recommended.
   / Planting Sunflowers #16
Until the newer vac planters became the normal Most popular planter was always a JD7000 finger planter as it will do corn or sunflowers with no alterations .
2008 Pierce Enforcer 61ft. Quint Ladder Fire Truck (A56858)
2008 Pierce...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
2000 Ford F-650 Truck, VIN # 3FDNF6541YMA65799 (A57453)
2000 Ford F-650...
7ft Rotary Cutter (A57454)
7ft Rotary Cutter...
