Plasma cutter
   / Plasma cutter #2
Those are two pretty different rating machines, what do you plan on doing with them? How often do you plan on using them? If there was just one brand to buy, there would be no others, right? :) So what do you value?
I'm looking at a smaller Everlast (60) as it's probably the best value.
I think if you interviewed professional welders/fabricators/etc., Hypertherm would come out as the #1 plasma cutter overall. Thermal Dynamics would be one of the better at a lower price point than Hypertherm.
   / Plasma cutter
I plan to cut steel:laughing: Like most of us here I just a hobby, I have a 2k budged I am still looking
   / Plasma cutter #4
What thickness do you think you'll usually be working with? What's the maximum thickness you want to be able to sever? Will you be doing a lot of dragging? Gouging? Piercing?
For $1000 you can get a nice 60A Everlast with another grand left over for consumables, steel, project parts, etc... but it may or may not meed the needs you haven't identified? :)
   / Plasma cutter
I will be working with 10gauge to 1/4 the most, I do have some projects in mind that would require some 1" plate.
   / Plasma cutter #6
ive had my Hypertherm Powermax 1000 in operation for nearly 9 years ( purchased 2005) without ANY issues what so ever. Not a glitch...not a hickup.
Does an amazing job ... cut up to 1" thick with it. With the fine consumable option i also cut 20g steel clean and sharp.
   / Plasma cutter #7
I have a powermax45. Had it three years or so. No problems and is an awesome machine. I can't remember what I paid for it three years ago but I smile everytime I use it. I did a lot of cutting on 3/4" material this week and no problems. I can't comment on other brands as I have not used them but the power max is good stuff.
   / Plasma cutter #8
I bought the Thermal Dynamics Cutmaster 42 and it has been great for about 6 months. I have had a couple of the cutmates and they where "OK", but hard to beat the price on the TD, especially with the bi-power set up. I have used it of my Miller Bobcat 250 welder/gen and it ran flawless in the field cutting "R" panel for a shop.
Thermal Dynamics Cutmaster 42 Plasma Cutter 1-4200
   / Plasma cutter #9
The PP100 will cut about any plate you come up to. Reliability has been excellent and problems almost non existent. We have a good many units sold in factory production. It's a quite seller because many of them go into industrial and factory settings rather than homeowners or small shops. We've been selling this basic model since 2008. First ones had needle style gauges. If the budget allows, and the power exists, it's hard to go wrong. IIRC, one place has seven or eight of them running. It's HF model, but it has been one of our best kept secrets.
   / Plasma cutter #10
Mark,
Are your plasma cutters compatible with the computer cutting tables using steeper motors.
What would command the plasma cutter to activate when you start the cut, and do you have air and arc instantly.
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2010 FORD F150 WORK PICKUP TRUCK (A51222)
2010 FORD F150...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
