I was at the local machine shop about a year ago and they had got a new toy and they had been playing around with it, you could see the metal that they had been cutting laying beside it. They had cut out stars, a moon, a heart and they looked good. The machine looked like it might have been a cnc plasma cutter and the table on it was a grating metal, and it had cut marks partially through the grating all over it and it was pretty deep. The original poster mentioned gouging out marks on his concrete floor, my question is how high would you have to elevate the metal off of your welding table to be able to cut the material that your are cutting without cutting gouges out of your welding table or the floor as the poster mentioned? My second question is the desicant material in the harbor freight filter the same as those little packs of stuff that is in packages that you order that is supposed to absorb moisture? They also say that you can replace the material in the filter, do they sell the desicant material and how much would it cost, and could you dry what is in the filter out and reuse it? Is one of the motorguard filters by itself enough to dry the air out enough to use in a plasma cutter or should you use additional means with it? The motor guard filter that I have the filter element is about the size of a small roll of toilet paper and I was told that you could dry it out and reuse it and that you could also use a roll of toilet paper for a filter, is this correct?
