plastic mulch layer
   / plastic mulch layer #11
Sweet automation job! Is the chain-and-jug the spacer reminder? Looking at the kid placing the plants makes my back hurt. How fast are you going - looks like the tamper tires are pretty close to his tree hand?
Nice.
Jim
   / plastic mulch layer #12
yes the chain and jug is the spacer, and by using a chain one Can easily adjust the length to what one wants or to adjust to the eye of the helper to get the spacing,
the travel speed is less than one mph, it takes some time to get the next tree out and to position it,
ones hand normally does not get near the press wheels, on the front there is a shank with an opener on it, and then there are the two sheet metal Shields that hold the hole open and is about 16" long that way the roots can be properly placed in the slot in the earth, and then moves the tree at ground speed until exiting the shields until the ground had moved back around the roots, supporting the tree, and on the normal your hand is well removed before the tree is near the press tires,
unless your moving slow the person on the planter will be over whelmed in trying to keep up. moving at one mph, you have about 15 seconds to place a tree, and if the tree has any problems in removal out of the box, or bucket or if bare root and tangles, if I remember correctly about 3/4 mph is what works about right for most people, (many tree planters are two seat so there is two planters working in alternating planting),
on the shrubs that were 6 foot spacing you really get a work out,
I normally provide the rider, with a loud whistle to blow if any problem occurred so the driver would stop instantly to allow the problem to be corrected, the whistle was just good so there was not a hearing problem,
   / plastic mulch layer #13
I know the post is a little old but
Man thats a fine mulch applicator.:thumbsup:
You've given me just what I need. Already got the trailer loaded with scrap so I can go to the local yard and get as much of the material as possible. I like to build with scrap iron.
doing a couple of acres of seed planted, not irrigrated water melons this year.
Prolly wont work - wish it would but I'm fixxing to go the mulch w/ tape and plug method if needed for next year.
Thanks for sharing and if anyone else has a unit they have fabbed could you please post TIA:)
2007 MACK CV713 ELITE DUMP TRUCK (A60430)
2007 MACK CV713...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2017 Toro Workman HDX Diesel Utility Cart (A59228)
2017 Toro Workman...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
