Play in 1525 loader
   / Play in 1525 loader
HVP
Thanks for your reply! But, the loader didn't act like this in the beginning. It is not a normal amount of play. I have yet to try to bleed the air out of the cylinders...will try that tomorrow IF I get out to where it is stored. It is certainly not normal. If I were to try to raise the tractor off of the ground using the loader the bucket will roll significantly under the pressure. It did not do this in the beginning. If I were to raise the tractor(even with the blade edge of the loader) it would go right up without flopping around. Thanks.
   / Play in 1525 loader #13
Hoka Hey,
I have never been able to lift the front of the tractor more than 1-2" just by using the loader. To lift the front I have to tilt the bucket.
Shawn
Did you ever come up with a resolution? I guess I have kind of forgotten about this issue because I haven't been using the loader very hard. Last week we were clearing a property of a bunch of trees etc so revisited this issue. I could hardly even grab a load from a compost pile to turn it.
   / Play in 1525 loader #15
I had an issue with cavitation in my 1548, the bucket would roll out quickly than the fluid would flow out of the cylinder at one one end faster than it would come in, causing a delay when returnig, Massey's solution at the time was to place an orifice inline to slow the whole process down and allow the fluid to escape slowly and allow fluid in and stop the cavitation, just slowed everything down and irritated you even worse, anyway at the time the mechanics told me there were some issues with the smaller tractors 1528 1533, but this was the first time they had come across it in a 1548. Cavitation would cause the sloppiness in the bucket as you have described, and Massey definitely had an issue with it, I believe there were even bulletins on it so check with your dealer. I don't have any problems with my 1533, but I have a John Deere 2305 and it has a similar issue, my deere dealer tells me it is common among all compact tractors as they don't have the pump capacities like the larger ag tractors maybe it's just his excuse not to fix it, but it makes sense. I find with my 2305 if i roll the bucket all the way out and hold the pressure there for a few second, then when i roll it back it stays rigid takes a little longer but it works. Hope this long and drawn out explanation helps.
Ryobi BS 900 9" Band Saw (A59076)
Ryobi BS 900 9"...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2016 Morbark Chipper (A55787)
2016 Morbark...
2019 Berky Weedo Amphi King 6450 Amphibious Workboat (A56857)
2019 Berky Weedo...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A52709)
2014 VOLVO A25G...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
