Please help, NO START
   / Please help, NO START #1
bx1860
Well I am in the process of buying a 1993 b2150, I went to the guys house today to look at it and possibly buy it, well I get there and he couldn't get it started, he tells me he put a new fuel filter on it today but it has air in the system, well we tryed to get it bleed out and no luck, it never even sounded like it was going to fire. Any help on the bleeding process would help, I would really like to buy this thing but I want to here it run before. Please help me!
   / Please help, NO START #2
An injector pump cannot pump air.
Not knowing that specific tractor, here are a few basics.
You need to start with a FULL fuel bowl and you can crack lines up to the injector pump until fuel squirts out of the line.
(some tractors have manual 'primer levers' to do this without cranking the starter)
Once you are convinced that there is no air up to the injector pump you can crack open an injector line at an injector while cranking the engine.
As soon as a reasonable flow of fuel escapes the line tighten it up and she should start.
If rather rough you can crack the other injector lines as well.
Be sure to re-tighten all lines well as you don't want leaks nor air to return to the lines.
Others who know the specific tractor might add some 'model specific tricks'.
Good luck!
2015 Ford Focus (A51694)
2015 Ford Focus...
2010 Ford Focus Sedan (A51694)
2010 Ford Focus...
8" CHANNEL IRON UP TO 25' LONG (A51247)
8" CHANNEL IRON UP...
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
