Please help!!! the stump is winning!
   / Please help!!! the stump is winning! #11
</font><font color="blue" class="small">( hacking them with my hatchet (sharpening every so often) )</font>
A reciprocating saw (cordless would be best) with an aggressive blade works great on cutting through those roots.
Sounds like you will get it. You can also beat it up with the backhoe - wiggle it a lot and give the occasional pull too.
Most important question: Are you having fun? /forums/images/graemlins/wink.gif
   / Please help!!! the stump is winning! #12
</font><font color="blue" class="small">( "I fought the stump and the stump won."
)</font>
UH MIKE . you are telling your age with that title, sadder part is i am older than you /forums/images/graemlins/frown.gif
   / Please help!!! the stump is winning! #13
Slow down!!!!!!
You have all you need with the backhoe, you just need to take advantage of what it does.
The reason the stump is still there is you didn't dig "DOWN" deep enough. Four feet is just loosening things up a bit.
A stump that big is gonna have feeder roots all over the place.
You need to dig down twice that far all the way around the stump. With the backhoe, it wont take that long, just plan your dirt piles so you can get in-between them.
Once you get the dirt out of the way, it will push over real easy. Sometimes it might fight you a little, but if you change positions, it will just fall over.
Never get in the hole with the stump. That's manual labor, and you NEVER do that when you have a tractor to do the work for you!!!!!!!!!!!!!!!
Good luck, relax and enjoy the tractor. You'll be done in no time.
Eddie
Howdy! WOOO HOOO!!! The stump is out!!! it's kinda on it's side and rolled out of the hole. Now what? I gotta find a place to put it, and figure out how to get it there. The FEL doesn't want to pick it up but about 6" off the ground, and half the stump is still on the ground. I dug down an extra 2' on all sides, then smacked it from the side at full force with the side swing a few times and what was left snapped. I even heard it pop! (the stump) I used the BH to roll it out of the whole. This machine is sooo awesome. (my first BH experience) It has an 18" HD bucket on it with 4 teeth. I may end up rolling it to a distant corner of the property, if I can't get it above the ground somehow. I live in Edgewood , very near wild waves / enchanted village. I'm glad I demo'd this thing. I really don't think I would be happy with anything less. The BH's that go on the ag series tractors can't compare. I can't see how they could. You guys are AWESOME!!! THANKS! Heya, 1 more thing. any ideas on how to move it? now that it's out of the ground? Thanks! Brian Lee Sparkeee24
   / Please help!!! the stump is winning! #15
<font color="blue"> , then smacked it from the side at full force with the side swing a few times </font>
Wow. I'm glad it was a demo. That sort of movement puts alot of stress on the bushings. Glad you got it out though. I have had luck carrying the stumps with the backhoe. In your case it might be too big. Does the loader not have enough lift capacity? If it does, wrap a chain around it and back to the bucket and you may have luck. Otherwise you may be rolling it like you said. Glad to see another NW TBN'er. I'm a little north of you in Snohomish county.
Howdy! I looked at the BX pics, and WOW!!! Your stump trophy is awesome! As to how hard I was on the backhoe...I am curious if you have seen the JD 110 setup? Do you think I am / would cause damage to it with the sideswing? It says you can backfill with full force, is this not the same motion? Just curious since I am going to purchase this model, though a different setup machine. Thanks! Brian Lee Sparkeee24
   / Please help!!! the stump is winning! #17
Full force with steady motion is easier on the equipment than the bang of smacking it into an imoveable object. Kinda like hooking a chain to the bumper of your truck and easing into the load vs. going full speed and jerking with the chain.
Edgewood eh? I'm just up the hill, or down depending on whether I'm at work. Nice area with some whacky politics.
   / Please help!!! the stump is winning! #18
Brian,
I haven't seen the 110 setup. I think highbeam said it already, and I agree. Slow and steady force should not be a problem. But banging the boom into a stump sideways seems awful hard on it. Maybe the setup of the 110 can take it? Not sure. /forums/images/graemlins/confused.gif And thanks for the nice comment. Happy tractoring, and show us some pics when you get your new machine.
   / Please help!!! the stump is winning! #19
I another trick is to grab the side of the stump and try to rotate or spin. If you can twist them a little they normaly fall over.
Brock 5 Ton Feed/Grain Tank (A55301)
Brock 5 Ton...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
Skidloader Mount Plate (A50775)
Skidloader Mount...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
