cowboydoc
Super Member
- Joined
- Dec 23, 2000
- Messages
- 6,737
- Tractor
- JD 8320 MFWD, JD 6415 MFWD, FEL, and cab, John Deere MFWD 4600, John Deere 4020, John Deere 4430, John Deere 455 mower, Deutz, and Gehl 4610 perkins skidsteer
The topic of sulfur and lubrication comes up repeatedly and is hotly debated here. I'm not posting this to start another of those debates. It has been my contention that loss of sulfur leads to significant lubrication issues. Without going into alot just take that for what it's worth. But one thing I feel that the masses should be educated on is that most engine manufacturers and the oil companies themselves feel it will be an important issue to lose the lubricity of sulfur in fuel.
As many of you know effective January 1, 2007 all fuel will be ULSD, ultra low sulfur diesel. Because of this a new low ash diesel oil has been developed which is called CJ-4. It will be required in most diesel engines that run ULSD to provide more lubrication offsetting the loss of sulfur. Those are not my words but the words of numerous engine mfg. and the oil companies.
In addition if you are thinking of buying a new diesel I would do it soon. The estimated cost to comply with the new EPA regulations is estimated to add $2000-5000 to the cost of a diesel engine and the resultant emission equipment. That is not my opinion either but from GM.
This will be due to increased engine cooling capacity and a completely new exhaust system. After the traditional downpipe there with be a DOC, diesel oxidation catalyst, which will treat exhaust prior to entering a particulate filter. The DOC will have to be automatically regenerated every so often to burn off the ash residue. This will create excessive temperature so additional cooling will be needed. The exhaust will then enter an diesel particulate filter which removes 90% of the particulates in the exhaust. This filter will have to be professionally serviced every 100k. The good news is it will result is cleaner air coming out than went in in large cities.
Dealers are expecting huge demands for 06 and 07 trucks and pickups, a 30% jump over 05.
