PLOW PULLING
   / PLOW PULLING #11
Right KentT
I don't think he is talking about a moldboard or 'turning' plow (or plows). Just sub soiling or middle busters, and turning up dirt.
He's talking of mounting these on a tool bar on his 3pt, so they will be side by each.
   / PLOW PULLING #12
Your tractor should have no problem pulling a 2-shank chisel plow in sandy soil. Traction is a problem in sand, not so much hp. With 4wd should work out fine. If it happens to be laying around in the grove, you could _try_ 3 shanks, if it is real sandy, & that is 37 drawbar hp, it may work well for you. But be prepared to change back to 2 shanks of it doesn't - the nice thing about bolt-on toolbar stuff, you can always remake it with a wrench. /forums/images/graemlins/smile.gif
The depth you go is your choice. Deeper pulls harder. So, if it doesn't pull, you just go shallower until it does. /forums/images/graemlins/smile.gif
Typical shank spacing to work up soil here with a chisel plow is 1 foot between the shanks. If you have more of a middlebuster, or shovel more than 2 inches wide for the plowing, then you may expand that to 2 feet or so. (Also, those bigger shovels take more hp, so don't go over 2 shanks then.)
As long as you center the load on the tractor, the actual spacing is up to you. But more than 12 inches of 'open space' between iron typically leaves unworked ground & a poor job for most soil conditions. So, if you have 6 inch shovels on a middle buster, 18 inch spacing often is best - if a 2 inch chisel shovel, 12-14 inch spacing is best..... Most of the time.
--->Paul
2026 tilt trailer (A56859)
2026 tilt trailer...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
