Plowing 2 acres with L2501
   / Plowing 2 acres with L2501
Thanks again for all the great help.
Ground has been plowed a few times.
Almost all small rootballs are gone.
I hope to someday have Smooth sailing with a new L2501 4wd Hyd...Yeew Haww
   / Plowing 2 acres with L2501 #22
I "plowed" 3 odd acres with a subsoiler then a 5' King Kutter rototiller behind my L3200 (same machune as your L2501, just a different engine tune). It did fine with loaded R4s.
A rototiller will be more manuvervable & generally more useful for you than a plow & disk harrows when dealing with a couple acres. Plow setup can be an art (a dying art at that). Pulling a $200 subsoiler & a tiller is a matter of lowering the 3pt & pushing on the go pedal until the engine bogs, then letting off a little.
   / Plowing 2 acres with L2501 #23
If I decide on R1's I will go with the more expensive radial tires rather than bias ply.
Tractor radial tires are low pressure, fat tires. Therefore, radials have a relatively large ground patch. Good when tractor owner wants to minimize soil compaction. Large ground patch aids with traction. Several radial tread patterns offered.
For low horsepower, medium chassis L2501 I do not believe you will accrue any advantage with radial tires over R1s or R4s. I would spend the radial money elsewhere.
Radials are air filled for float and flexibility in Europe.
   / Plowing 2 acres with L2501 #24
My L2501 (geared) runs a two bottom plow easily. I've plowed in the summer on fairly hard ground and it rips right on through.
   / Plowing 2 acres with L2501 #25
I think it depends on the blade (s) on the plow. I got a single bottom (thinking it's 14") that I bought at a used farm equip. auction. I have a L3301 and I had that sucker loaded down plowing with this plow. It was a working mighty hard. However, the ground had never been plowed and was pretty hard clay mix. I was letting her go deep, too. Got it done and it was rough trying to disk it after the plowing. I really had some dirt turned up !
   / Plowing 2 acres with L2501 #26
Plowing for me is turning over the top 6-8"... I hope you were not trying to turn over 14"
All really great help.
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
1266 (A50490)
1266 (A50490)
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53472)
Mitsubishi FG35...
