Plowing in Maine with a 1948 Farmall H
   / Plowing in Maine with a 1948 Farmall H
That's her.
Now you can see why my girlfriend is jealous, she's a looker
   / Plowing in Maine with a 1948 Farmall H #12
That H looks like it's got at least another 60 years of service left in it. :)
   / Plowing in Maine with a 1948 Farmall H #13
Always good to hear see yesterday's iron giving its all. :thumbsup:
   / Plowing in Maine with a 1948 Farmall H #14
Nice picture! That is certainly a more robust plow than the stock IH grader blade that I used with our Farmall 200 to do my driveway in NY in the late 1980s ...
   / Plowing in Maine with a 1948 Farmall H #15
That’s a rare one, factory LED’s !
   / Plowing in Maine with a 1948 Farmall H #16
That's a great old tractor!!! Thanks for posting the pic. My father had a Farmall back in the '60s which had a snowplow on front but which mounted back around the rear axle if memory serves me correctly. I can't say how it went up and down as I've only seen the plow setup in family pictures but remember the tractor, before he upgraded to a "modern" 8N.
   / Plowing in Maine with a 1948 Farmall H #17
Never been on a tricycle type tractor. Is that a bit dicey plowing snow covered hills?
When I was a kid, our neighbor farmed a 160 acres, had about six different farmalls to do it.
   / Plowing in Maine with a 1948 Farmall H #18
Modern 4 wheeled tractors aren't much if any better. All non-articulated ones just have a single pin the front axle pivots on. If you ever lift something to heavy with the loader & the back end comes off the ground, you are screwed. The front axle will flop to one side & the tractor will roll. There are stops to limit how far the axle will pivot. But by the time you hit those stops you have to much momentum & are going over anyway. Pretty much all the stability on a tractor comes from the rear axle.
   / Plowing in Maine with a 1948 Farmall H #19
A Farmall H was the first motorized vehicle of any sort I ever operated, back in 1972. Nice to see one still working!
   / Plowing in Maine with a 1948 Farmall H #20
Just a minor correction, that H has what is called a narrow front end a tricyle front end only has one tire centered on the bolster.
I see why you had trouble on ice with those chains being twisted street cross chains. I don't know what gear you where in but with that style of chain tire speed will help some times. When I ran those at times I'd spin out in 2nd or 3rd gear, go up into 4th and it would chew a bit better.
They are getting harder to find but a few 100 pound wheel weights would help quite a bit.
And if you want to be amazed get a set of the newer Euro style chains, they are expensive but amazing.
Nice to see an H earning it's keep, if you can find one a weather or wind breaker will make it a lot less uncomfortable in the winter.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A56858)
2012 Freightliner...
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
2014 Chevrolet Equinox AWD SUV (A56859)
2014 Chevrolet...
Giyi 27" Mixing Bucket (A57149)
Giyi 27" Mixing...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
