For sprinklers you can use saddle tees, and there is no obstruction of flow whatsoever. Moreover, you can put saddle tees in/on in a tenth the time of a tee fitting.On poly pipe, each connection (tees or elbows or each connection) are inside the working diameter of the pipe. To get the same flow and pressures from poly pipe, you need to use bigger size than you do with PVC. I need to quit being so lazy and get my sprinkler system designed and get the pipe in... no reason to delay it (other than finding time).
Wrooster
