plows
   / plows #1
wilsonfarm09
graham nc.
massef fergson grah
what will i need to make a depth wheel for a ford 101 3 bottom plow
   / plows #2
Probably find an old scrapped plow and put the wheel on yours. Fabbing one and getting it to work correctly would be a nightmare.
Here is a photo of one if you want to try.
   / plows
thanks for the reply but i did not see adepth wheel on your photo
   / plows #4
Perhaps you can post a photo or drawing of what you want.
   / plows #5
maybee he means something like this?
although for a 3 bottom, if its setup correctly it should need no such wheel.
   / plows #6
I really like the toolbar for the plows on your set up. Simple and neat. Who makes that? I'm looking into building one for worked ground, turning in cover crops etc. Thanks.
   / plows
yes i can't get my draft control working right so i am useing the up and down to to lift and lower plow so i thaugh i would use depth wheel to set plow depth does all this make sense . thanks
   / plows #8
Makes sense to me. I don't have draft on my tractor, I have to put position lever back to the same spot. It might be beneficial for this and other applications to have a stop you can move on position control. What are you pulling with?
   / plows #10
That's a nice plow, GWDixon. Does the depth wheel assembly bolt to the extended landside on the third plow?
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
FAKE (A52472)
FAKE (A52472)
JOHN DEERE 9R640 LOT NUMBER 252 (A53084)
JOHN DEERE 9R640...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
