brandoro said:Maybe not all 'professional' installations are the same. I have seen 'drops' going upward from the main line in a body shop where they are quite concerned about moisture in the air.
I have about 30' of 1" copper line between the compressor and the 3/4" line that runs across above my bench that I expect condenses out most of the moisture. Has worked very well for me and uses fewer fittings.
Not all install's are professional. We had such an up flow system in my body shop. However, we put it in our selfs.
An up flow system can work, however the first sign of water in the air, is when the main trunk line is loaded with water, rather than a small amount in the drop line. If you reach this point, you have to bleed out the system to drain the trunk. Shutting down production while the air supply recovers, add to that the noise of such a bleed down, (+115db) and the mess. We changed it to a down flow and were much happier.
These problems are exacerbated by very high volume use of the air supply. If you don't intend to use a lot of volume, and can be very diligent about draining the condensate you may not have much trouble with an up flow.
A good drier after the compressor is always a good way to eliminate all these problems.
