Polaris ranger - major problem
   / Polaris ranger - major problem #11
the running time all depnds on where you live and whats the temps outside.i know where i live if i run my hpx for 30 minutes it up to full warmed up temp believe me it is.lol now someone way up north might have to run thiers longer. but down in south louisians we got heat and humidity and it gets hot quick.
My apologies for not making it clear that this didn't just happen. I've kind of been away from this website for several years and just started reading it again. I posted this because the design hasn't changed hence the potential still exists for this to happen to someone else. Re: the amount of water issue - The ranger doesn't use an oil pan on the bottom of the engine. It uses a plastic container in a vertical position next to the engine. A rubber hose comes out of the bottom the reservoir and connects to the engine so a small amount of water settling to the bottom of the reservoir and entering the small diameter rubber hose will occlude all oil flow. Certainly a fluke and there had to be enough water AND that night had to get cold enough in my garage for the water to freeze (which only happend when it gets down around 10 F or so. Doesn't happen often but once was enough!) I was just putting this out there as an awareness issue so if someone else has one in a cold climate they can check once in awhile for water build up.
   / Polaris ranger - major problem #13
Interesting.....
I haven't looked at one, but I understand what you are saying about the design where ice can choke off the oil supply. This is not just a snowmobile engine since most are two-stroke and rely on cold air to run. But Polaris engineers live and breathe cold air six months of the year up in northern Minnesota so they SHOULD understand and anticipate cold weather issues including condensation.
   / Polaris ranger - major problem #14
I had the exact thing happen to my Polaris ATV and it only had 50 hours on it but was one month over the warranty period. They wouldn't even sell me the parts at cost, so I bought a used engine off ebay. No more Polaris' for me. When I was looking at a side-by-side, I just went with Kubota 900 and love it.
John Deere 5105M (A53317)
John Deere 5105M...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
