POLE BARN ALARM SYSTEM
   / POLE BARN ALARM SYSTEM #11
If the pole barn is near your house and you are there on a daily basis, a dog is a good added measure. Since they do need to be fed daily it won't work if the pole barn is remote.
   / POLE BARN ALARM SYSTEM #12
I use a 12 volt siren from Amazon for about $40 - 140db - that's loud. I used a battery that came from my wife's Honda when it needed to be replaced. The battery was too weak to crank a starter, but has lasted 2 years powering that siren when needed. Add to this circuit any number and type of switches - including a manual "panic button" - and you have a very inexpensive alarm that works incredibly well. It's so loud, you can't possibly stay in the building while it's going off.
   / POLE BARN ALARM SYSTEM #13
When we built our place I had the stables tack room wired for the alarm system I put in the house. There is a separate keypad in the tack room and that stays armed even when the house is not. I also installed a beam smoke detector from one side of the stables to the other. It is always armed. If either goes off the sirens in the house go off. Since I had smoke detectors installed with the house system there are inside and outside sirens that you can hear for miles. If you use a DSC brand system, which most do, they can do a lot with one panel and multiple keypads instead of installing 2 systems. One Cat5e wire buried from the house to the stables runs the keypad, door switch and smoke detector.
   / POLE BARN ALARM SYSTEM #14
We got our alarm system from ADT and got the shop and the house for the same price (we had to buy extra sensors but the monitoring is the same). Our shop is 50 or so feet from the house and still have wireless. We are very pleased with ADT. This is a cellular system
   / POLE BARN ALARM SYSTEM #15
My shop got broken into June 2012. They took about 5K worth of tools and welders. Thankfully I have full replacement on my policy and was covered.
After that I made my own alarm system then invited a local security company to come and see what they could add to it that I may have missed.....they could do nothing for me other than add a line to call local authorities, which are 30 minutes away at best. I used a motion detector w/ two lights (I think $30 from Lowe's) and mounted it in a location that covered the entire shop. In line with that I added a 140db buzzer alarm into the eve facing the house. The entire system is on a switch that is mounted remotely to avoid being noticed. When I arm the system is buzz's for 30 seconds then shuts off. I also barred all the windows and padlocked the doors from the inside. The walk in door also has a deadbolt that is keyed from both sides and the door frame has been reinforned w/ 1" angle to avoid being kicked in.
The motion detector lights work great. Twice I have locked the cat inside by accident (it was sleeping on the tractor seat). When it decided to wake and move around, it set the motion lights off which sounds to buzzer. I grabbed the gun and head out to investigate only to find the cat setting in the shop waiting for me. I even reached in an open window to test the system and that set the alarm off.
Loader Bucket (A53421)
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2018 John Deere 5075E MFWD Tractor (A53485)
2018 John Deere...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
