Pole barn Questions
   / Pole barn Questions #11
I'm in the early stages of planning a pole barn build for next summer. I have a couple of questions. When ordering 6X6 posts, do I need to order extra to frame out for the doors or is there another way? Would it be ok to build in stages or am I better off waiting to have enough money for all the material before starting to build. I was thinking 3 stages. First stage is doing all the frasming, second the roof and third siding. There may be a few months between phases. It that Ok? Thanks! TC
You will need 6x6 posts to frame the door. It's better to sheet and roof the wood instead of letting the wood set out in the weather.
   / Pole barn Questions #12
if you are getting solid 6x6 treated they will warp if you get laminated beams they will not warp as bad.
my best advice is to get it done ASAP to dry in stage (roof & walls) all up.
mark
Very Good Advise Here, I totally agree!!!
   / Pole barn Questions #13
what I did took 8 more years to get it all filled to grade and concrete in...
mark
The 6x6 treated posts will not warp if they are not exposed to the weather. 6x6 posts will warp if they are exposed to the weather. My pole barn has treated 6x6 posts and have stayed straight for twenty years now. But not for a second would I use a 6x6 treated post for my outdoor deck. These are exposed to the weather. The deck posts are made of laminated are 2x6's.
John Deere 1770NT (A53317)
John Deere 1770NT...
2018 KUBOTA SVL75-2 SKID STEER (A52707)
2018 KUBOTA...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
