Pole Barn Roof Question
   / Pole Barn Roof Question #11
We have two buildings with metal roofs (I built one of them). Both use an insulated blanket that goes under the roofing and on top of the framing. Just lay it in place and screw down the metal roof on top. Makes a nice white finished look inside and keeps the condensation off. Did I mention cheap?
   / Pole Barn Roof Question #12
I have a 24X36 pole, it's only insulated on the under side of the roof.
Doesn't sweat and doesn't feel humid, never has. My tools say the same.
Edit; mine sounds the same as Johnbro.
   / Pole Barn Roof Question #13
That much condensation also sounds like poor ventilation may be a factor. Airflow under the roof will dissipate moisture and reduce condensation. Simply adding insulation to the underside of your roof may just trap the moisture between the metal and the insulation and create a mold colony.
Yes, I'm sure that poor ventilation is most of it. The only time it's a problem is after condensation freezes over night and the sun hits it in the morning. The beads of water roll down to the strapping and collects into droplets. Happens for 5 minutes and it's done...
What does everyone think about a wood roof with shingles with a ridge vent? think that will help with the moisture problem? Or will the wood just soak up the water?
   / Pole Barn Roof Question #15
I had my builder put tyvek under the roof on top of the purllins and haven't had an issue with condensation.
I do have ridge vent and 12" sofit all the way around including the gable ends.
tom
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
1065 (A53342)
1065 (A53342)
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2014 Ford F-550 4x4 Crew-Cab Flatbed (A52377)
2014 Ford F-550...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
