Pole Barn Roof/Wall Perlins
   / Pole Barn Roof/Wall Perlins #11
If at all possible make it bigger. If money allows and space allows go larger. I was just talking with someone yesterday about this. He built a 24X28 garage, hind sight he said he should have made it bigger and taller for attic storage.
Just my humble opinion. Good Luck!
I agree...this project started out as a pre fab 12'x18' shed grew to a 24'x32' pole barn and due to money and where we need to put the building settled into the 24'x24' project we have going now. :)
   / Pole Barn Roof/Wall Perlins #13
Would you use 2"x4"s or 2"x6"s for roof perlins? I have some people bidding 2 x4 on 24" centers for the roof and one other guy is bidding 2x6 for the roof and 2x4 for the walls. Now 2x6 sounds like it would be more substantial, is it a good idea? Trusses spaced 4' on center
Also, some are bidding 6"x6" poles and others are bidding 4"x6" pole.
I'm in the middle of getting bids as well. I have 6"x6" pole with 2"x4" prulins. Both roof and side nailers. Trusses will be 2 o.c. because I'm having an open span Grambrel roof installed.
Wedge
   / Pole Barn Roof/Wall Perlins #15
JDGreen, Look below in my Picasa link about the barn I just had built. I can Highly recommend a builder for you;)
   / Pole Barn Roof/Wall Perlins #16
I have 24" OC trusses with no roof purlins. 24" OC wall purlins on 6x6 8ft OC posts. 2x12 boxed headers holding the roof up.
   / Pole Barn Roof/Wall Perlins #17
24' x 24' x 10' 6" with 6/12 roof pitch. Steel roof and wall.
The only thing I would note here is that if you ever have to get up on the roof, make sure you use a teather. Mine is 5/12 and even with a light dew it is very slick. I came off it once while building it. Now I won't get on it without a teather.
   / Pole Barn Roof/Wall Perlins #18
I built a 32' x 64' last year with 4' truss centers, 8' post centers and 2 x 4 purlins. The roof feels fine when I was walking on it to put a chimney in. The only thing I would reccomend was going to 1/2" sheathing rather that 7/16" if they are quoting that. Not sure of the code where you are, but here you need roof clips with the 7/16" and not the 1/2" (But I put them in anyway):D
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
2020 KUBOTA RTV...
ITEM LOCATION (A53084)
John Deere BD1108 (A50123)
John Deere BD1108...
