Pole Barn
/ Pole Barn #1
Nissan197
Platinum Member
Kansas
Mahindra 3215 4WD
See if I can attach some pictures of the new pole barn under construction. It is a 40 X 50 with a 15' lean- to off the east side.
/ Pole Barn
Here are a few more pics......
/ Pole Barn
Few more.........
/ Pole Barn #5
Nice building....I'm looking at building the same size. Would like to see more pics as the build progresses especially interior shots once you get your concrete, insulation, etc.. Tks!
/ Pole Barn
Few more pics........
/ Pole Barn
These are the final four pics. The crew finished up yesterday. As you can see my leveling skills are not that great. First time I ever leveled something this large, but I should be able to still go in and use the fel and box blade to get pretty level before bringing more gravel in for the concrete crew. I am using a different contractor for the flat work. Hopefully I will get that done next month sometime. I will probably go with 5" depth of concrete. I was pretty impressed with the barn company. The crew was very nice and worked in teen degree temperatures with blowing snow some days. It was obvious they are experienced and I did not hear any complaining (To my face anyways). They were probably happy they had work. It was a very good experience.
/ Pole Barn #12
I wish I had added a lean-too on my existing pole barn shed. I really adds a lot of space and makes it easy to get into and out of lean-too for attachments, storage ect. We added a one to my brother's pole barn shed and it adds a lot of flexibility for big equipment that makes it difficult to store and work around in his main shed. Lean-too is a nice place to store equipment that is not used frequently but still needs to be stored out of bad weather.
/ Pole Barn
Finally getting around to obtaining bids for concrete. Sticker shock I must say. I plan on having the following done:
40 X 50 interior of the barn
12 X 10 drive out the front
9 X 10 drive out the east side under the lean-to
The concrete will be 5" thick, 4000 psi. Both would get area level and put down rock.
I have obtained the following bids:
8K and this flatworker would use heavy steel mats in the concrete. This guy did all my concrete at my current house and I was very happy.
9K from another who would use steel rebar on 2' centers.
These prices seem fair?
Both recommended going with 5" due to the barn sitting out all by itself. I will have my Mahindra 3215 parked inside the barn and some woodworking equipment and all sorts of other things. Nothing that I can think of weighing over 4 - 5 k lbs.
/ Pole Barn #14
Thanks for sharing pics of your building. What type of insulation/vapor barrier did they put up? I live in an area that can see cold temps too and was wondering what your builder used and what they charged you to install.
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
(1) 20 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
3pt Countyline Auger w/Bit (A64126)
3pt Countyline...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
