Pole Building Size?
   / Pole Building Size? #11
Tall and as big as you can afford they fill up real fast and you still find stuff parked outside cause the barn is full.
   / Pole Building Size? #12
I have shops with 10' and 12' doors. You may be able to squeeze more out of it but generally your door height is two foot less than your sidewall height to allow room for the door tracks, etc. So with your 10' sidewall you would have 8' doors and 12' sidewall 10' doors.
I have a lot of equipment and vehicles. I have a 95 hp tractor with a cab, an International 33,000 lb 4x4 truck, enclosed trailers with AC's on top, and all of it will fit (barely) in a 10' tall door. RV's or semis might need something taller but most stuff you will encounter will fir in a ten foot door. That being said there is no way 8' would cut it.
2005 GMC C8500 CHASSIS TRUCK (A54756)
2005 GMC C8500...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
2008 Ford F-350 (A53422)
2008 Ford F-350...
