Pole building using my oak trees
   / Pole building using my oak trees #11
use your Oak logs and in 20-30 years replace if necessary...
   / Pole building using my oak trees #12
The trick on any wood post in the ground is to keep them dry. Make sure that the soil slopes away from them and there is no standing water. I repair fences all the time, and in every case, water sits at the fence post and rots it away there. Even if the water is gone in a day or a few hours, it's that moisture that causes the rot. Add eves and gutters if you can. Anything to get the water away from those posts is your most important goal in logevity of the poles.
Good luck,
Eddie
   / Pole building using my oak trees #13
Where in middle tn? I am over in perry county,want to use my trees for a house maybe someday. I Figure I have some really nice trees for lumber!
   / Pole building using my oak trees #15
Use Locust for the main support poles if available locally.,it will not rot nearly as easy as Oak,also very strong.Theres fence posts around here over 100 yrs old Locust still in good shape...IMO Locust is the best wood for any application where wood meets the ground....
2023 CATERPILLAR 259D3 SKID STEER (A52709)
2023 CATERPILLAR...
2188 (A58376)
2188 (A58376)
Giyi Stump Grinder (A57149)
Giyi Stump Grinder...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
2018 Kaufman 20-Ton Equipment Trailer, VIN # 5VGAP2528JL004708 (A57453)
2018 Kaufman...
