Pole & Truss Problems
/ Pole & Truss Problems #1
RxRatedZ71
Edmond, OK
JD 3203
So after many months of browsing TBN project threads and posts (I think I'm on page 76) I've decided to build my own polebarn. I've decided on a 30x40 with a 10' shed along one side. My sidewalls will be 12' high, and I'll have a single 16'x8' OHGD. My needs are basic: tractor storage, lawn mower storage, hobby/work shop space, etc. I can't afford concrete right now so gravel will work for my floor. I want to use SmartBoard panels for the siding and a 3-tab asphalt shingles for the roof. I just don't care for the steel panel look.
I've cleared my pad and had 40yds of pack-dirt brought in this week so I'm ready to roll with this project, but my problem is that all the plans out there indicate 10' spacing for the poles. With the asphalt shingles, I thought the roof would be too heavy for 5'OC truss spacing, so I've changed that to 4'OC. This causes me to change to 8' pole spacing. My local city codes dictate that I need a set of engineered plans OR comply with 2006 building codes in order to approve my permit. Now I can't find any plans out there that use this type of material with similar spacing to my project. :confused2:
Was I wrong in over-estimating the weight of the asphalt shingle roof? Would the 5'OC truss spacing actually work? I plan to use 2x4 purlins (either 16-24" on center) and then obviously 7/16 OSB underlayment.
P.S. I'll post a few pics of the barn site.
/ Pole & Truss Problems #2
Go with a taller door! Read this in 2-5 years and you'll be saying, **** I should have listened.
/ Pole & Truss Problems #4
Local code is what you have to follow, and what we say wont matter. Since you are new to building, I would strongly suggest that you contact your inspector and explain to him what you are going to do, then ask him for his advice on what he'd like to see. In my experience, they are usually very responsive to giving out advice when asked for it in a nice manner. I think they get allot of grief from people trying to BS them, and it's a nice change when somebody is nice to them.
Have you used SmartBoard before? It sounds like a nice product, but I question how well the seams will hold on you and how cost effective it is. I tried doing the same thing with Hardi Panels, and regeret it. I love the concrete fiber type products for exterior walls, but have come to realize that with 4x8 sheets, the seems are a big issue. If they crack at all, water gets behind them and you have to deal with where it goes when it gets to the bottom of the wall. The house wrap does a good job of keeing the water out, but if you have any areas that the house wrap doesn't lead the water away from the wall, you will have moisture issues inside your walls. With a pole barn, it might not be that big of a deal. With a house, it's a disaster.
I've also recently discovered James Hardi house wrap. From what I can tell, it's easily twice as good as Tyvek or the other brands out there. The weave it much tighter and it feels thicker to me. While I've never had a problem with Tyvek, I'm only going to use the James Hardi wrap in the future.
Good luck,
Eddie
I also agree on the taller door. My shope has 12ft walls and I went with a 10x10 roll up door. I debated on going wider, but wanted the wall space. I had another shop with a 12ft wide door and didn't think that I needed that extra width. So far, I don't miss it, and would go with the 10x10 again. I really like roll up doors, and strongly suggest you look into them. They don't take up any ceiling space, which is nice for lights and attic access. They close fairly tight, keep out the elements and wind better then most other types of doors, and they are not that expensive when compared to other types of doors that you would buy. I bought mine from Muellers, which manufactures their own doors. I really like dealing with them, and highly recomend them too.
/ Pole & Truss Problems #5
I am curious about the type of sheathing or shingle base you intend to use with your trusses 4' OC ?
Most roofs with more than 2'OC trusses employ 1x or 2x 4 lattice and metal roofing.
/ Pole & Truss Problems #6
I think you will have to go with trusses on 2' centers max. I don't know of any sheathing, ply or osb, that will meet code with trusses on 4' centers. That is the disadvantage of asphalt shingles over metal roofing.
MarkV
/ Pole & Truss Problems #7
I've built several shelters that used laminated trusses set on 5' centers and then decked with 2x8 T&G yellow pine and then shingled but it would not be cost effective for that size pole barn IMO...
/ Pole & Truss Problems #8
The pole and truss spacing can be whatever you want -- just need purlins designed to hold the weight.
You could have 4' or 12' spacing with the correct trusses and purlins. Talk to the truss companies engineer.
/ Pole & Truss Problems #9
We are just looking ourselves at putting up another barn/coop. We would use fiberglass shingles not asphalt. Both are available but not that much price difference. Fiberglass should last longer and more fire resistant. Is there a particular reason you would use asphalt?
/ Pole & Truss Problems #10
not exactly if you want to build to most standard building codes...the beams that sit on the poles have to hold distribute all the weight...that weight (both live and dead loads) is what determines the size of the beam and the spacing of the poles...
...the type and size of the roof determines the the design (calculated live and dead loads) and spacing of the trusses (including the weight of of any lattice/purlins)
FWIW...almost any carpenter can cite common practices that are well within BC guidelines
I think they may have meant it in a general sense ...in reality even "fiberglass" shingles are just "fiberglass reinforeced asphalt"...unless you are referring to a hard shell type roofing tile?
/ Pole & Truss Problems #11
Sounds to me like you guys are not talking apples to apples here.
Mikef is talking traditional pole truss and purlin.
Sounds like you are talking about pole, beam, and " house style" trusses?
/ Pole & Truss Problems #12
The OP stated they intend to use "asphalt shingles"...
I put down wood shingles on lattice (not solid decking) but I've never seen composite shingles put down on anything but a solid shingle base like OSB or plywood etc...
/ Pole & Truss Problems #13
My point was that an engineer can design whatever you want to build -- the spacing will determine beam sizes etc. You could have 10' pole and truss spacing with purlins and OSB/asphalt.
Or you can build to the local prescriptive codes. Which are generally less expensive to implement.
/ Pole & Truss Problems #15
Maybe it should start with a soil analysis to determine load bearing abilities.:thumbsup:
Then we go on with that other stuff.:D
Then we find the design loads are too high for the soil bearing abilities.:cool:
Then we design a bigger pole or sink it deeper :)
Then we go thru the other stuff again.:D
Then the owner wants it four feet higher.:laughing:
Then its Miller time!:licking:
Wow, lots of great feedback here. Keep it coming. I thought I had stated in my original post that I was using traditional purlins on either 16 or 24" centers, then 7/16 OSB, then roofing felt, then shingles. The local Lowe's has standard 20yr asphalt shingles for $51 a square. When I ran my original materials list and counted the boards, roofing, and siding material needed, I was able to save about $2k when compared to traditional metal "skin". Although I save money with that combination, it sounds like I may spend more in the long run either "beefing it up" to code OR rebuilding after it collapses b/c of poor planning initially. :confused3:
I think I will re-run my numbers and re-figure my cost again using traditional spacing and metal. Maybe if I spread my poles out to 10'OC I can save a bit with my lumber figures. A local ag store and lumber supplier has metal barn kits for sale for the DIYer and a 30x40 is $6200, but uses 29G metal.
Back to the drawing board!!!
/ Pole & Truss Problems #17
You need to get a copy of your local building code, then forward it to the engineer at the truss company and be sure to tell him you want shingles. The engineer will tell you about pole and truss spacing, purlin size and spacing, etc.
Resist the urge to take the cheap way out. You'll just be redoing it again in a few years. There's an old saying.......there's never enough money to do it right the first time but there's always enough money to do it over.
/ Pole & Truss Problems #18
29 ga. is find for the sidewalls. I like to use 26 ga. on the roof. I have built several this way. 6x6 on 12' centers with metal "chicken house" trusses and 2x6 perlins. 26 ga. metal screwed to the perlins.
Of course we have almost no snow load here in Alabama.
Chris
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
generator trailer (A61569)
generator trailer...
