Popup Camper Conversion To Toyhauler
   / Popup Camper Conversion To Toyhauler #11
My tongue weight is 16% of total without the 550 lbs of motorcycles on it. Without the cycles the total is 3710 and the tongue is 580. I agree I am going to try to move the axle forward as much as possible. I would like to see about 150-200 lbs less on the tongue.
Yes, looks like your on top of things and good call on moving it. Improper hitch weight is not something to play with. I pulled a 5x8 open utility behind my CJ7 for 5 years, never had a problem...... until one day back in the 80's. I used to build fences and decks as a second job and always pulled that trailer with various loads on it. One day I loaded 22 - 80lb bags of sacrete and 20 4x4x8's and got the COG wrong. When I hit 55 mph on I95 it started to swing. Now I know all about that swing as I had experienced it a few times at much lower speeds(bigger trailer and much bigger loads). This time it was immediate and violent, the tail wagged the dog and we flipped doing a 3/4 roll then hitting a metal light pole wheels first. Neither one of us got hurt(lucky).....well pride took a big whack. Ever since then I have been extremely wary of loads and their placement on trailers.
Oh, and one more odd bit of info about that incident. I had a Golden and back then and he was 4. He always went with me unless I was dressed for work, and would patiently wait at the door, first out and right into the jeep. That day, the one and only day of his 13+ year life, he refused to go. I stood there with the door open and even called him.....nope not budging. I can't explain it, but he knew...it was not a coincidence.
So, moral of the long winded story.....fix the trailer COG, or buy a Golden:laughing:
Good story. You obviously had too little tongue weight to cause sway. I should not have that problem. My problem will be payload related on the tow vehicle. I have an 1800 lb payload capacity that I don't want to exceed. This tongue weight would prevent me from hauling anything in my truck bed. Here are pics of my tow capabilities. 2011 f150 ecoboost screw.
Well I have finally finished this project. I added a second 3500 lb axle directly in front of the existing one. Taking it out this weekend loaded down. Going to weigh it Sunday if I have time.
MotorSeven said:
Outstanding!
Now where are we going to go ride??
This weekend we will be at little Egypt riding area in southern Illinois. I will be taking three bikes on the camper and a 4 wheeler in the bed. Madden voyage so hopefully nothing brakes.
I just returned home from the first trip with the camper. Traveled about 4 hours hitting speeds up to 70 mph. Towed great and it was tested on some pretty rough roads and bumps in a construction zone. I now feel good about the setup. I also was able to get to the scales before unloading. Total weight was 5020 with 4040 on the axles and 980 on the tongue. This was with 3 motorcycles on the trailer and trailer packed with all gear, food, cooler, etc.
I also weighed with the weight distribution hooked up and it added 140 lbs to that 4040 axle weight. Thought that would interest some.
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
Towable arrow board (A55973)
Towable arrow...
TANK MANIFOLD (A55745)
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
200722 (A51247)
200722 (A51247)
