HCJtractor
Veteran Member
- Joined
- Jan 28, 2009
- Messages
- 1,519
- Location
- upstate South Carolina, Greenville
- Tractor
- Kubota M6800, Massey Ferguson 240
I occasionally need to cut steel at the farm, such as cutting off bent lift arm pins (7/8" diameter), or cutting off bolts or small pieces of steel, etc. I have a larger oxy/ace set, but I hate to transport it. Would one of the little totes work for occasional cutting of thicker steel like this? I realize they are limited in flow and volume, and not designed for applications like this, but would it work for occasional use like this? Is it worth having? Do any of you guys use these regularly for cutting steel (not sheet metal) and if so, what applications do you use it for. Or is is it a $400 waste of money.
I don't have electricity there so its either carry the generator there and use a angle grinder, or load up the heavy torch set and transport it, neither of which is quick and easy. I was thinking if I could just grap a tote and torch, I could see how it would be useful, if it worked on thicker steel. Again, I am not talking about using it a lot. There are also several old implements laying around that I would like cut pieces of of to use to build other stuff in the shop.
